Good morning,
i measure the temperature from my hotwater tank (Temp 6) with an ESP8266 (lets call it Device A) and a DS18B20 now i want to display it with another ESP8266 (lets call it Device B) and a 7-Segement display.
Here is my Code and log from Device A (Temp. measurement)
esphome:
friendly_name: TempMessung
esp8266:
board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "jh2gFoaibuJ28wx75tNC8of2/bhn1KqU4D6WtUbKtJo="
ota:
- platform: esphome
password: "a43a1360c4751274ba63c75c2e142fa7"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Tempmessung Fallback Hotspot"
password: "gjsOAtdVXxBf"
captive_portal:
one_wire:
- platform: gpio
pin: GPIO14
#update_interval: 10s
- platform: dallas_temp
address: 0x373ce10457e4a428
address: 0x033ce10457ebb428
address: 0xbc3ce1045764f628
address: 0xc63ce1045730b128
address: 0x233ce10457f2c528
unit_of_measurement: "°C"
device_class: "temperature"
address: 0xd53ce104578cbd28
address: 0x6d3ce10457dc7b28
address: 0x1a3ce1045774c728
address: 0x7c3ce10457250f28
address: 0xfb3ce1045776af28
- platform: adc
pin: A0
update_interval: 1s
filters:
- multiply: 3.3
INFO ESPHome 2024.9.2
INFO Reading configuration /config/esphome/tempmessung.yaml...
INFO Starting log output from 192.168.0.116 using esphome API
INFO Successfully connected to tempmessung @ 192.168.0.116 in 0.004s
INFO Successful handshake with tempmessung @ 192.168.0.116 in 2.377s
[05:50:42][I][app:100]: ESPHome version 2024.9.2 compiled on Nov 18 2025, 05:34:21
[05:50:42][C][wifi:600]: WiFi:
[05:50:42][C][wifi:428]: Local MAC: 08:3A:8D:CF:AE:A3
[05:50:42][C][wifi:433]: SSID: [redacted]
[05:50:42][C][wifi:436]: IP Address: 192.168.0.116
[05:50:42][C][wifi:439]: BSSID: [redacted]
[05:50:42][C][wifi:441]: Hostname: 'tempmessung'
[05:50:42][C][wifi:443]: Signal strength: -65 dB ▂▄▆█
[05:50:42][C][wifi:447]: Channel: 1
[05:50:42][C][wifi:448]: Subnet: 255.255.255.0
[05:50:42][C][wifi:449]: Gateway: 192.168.0.1
[05:50:42][C][wifi:450]: DNS1: 192.168.0.1
[05:50:42][C][wifi:451]: DNS2: 0.0.0.0
[05:50:42][C][logger:185]: Logger:
[05:50:42][C][logger:186]: Level: DEBUG
[05:50:42][C][logger:188]: Log Baud Rate: 115200
[05:50:42][C][logger:189]: Hardware UART: UART0
[05:50:42][C][gpio.one_wire:020]: GPIO 1-wire bus:
[05:50:42][C][gpio.one_wire:021]: Pin: GPIO14
[05:50:42][C][gpio.one_wire:080]: Found devices:
[05:50:42][C][gpio.one_wire:082]: 0x373ce10457e4a428 (DS18B20)
[05:50:42][C][gpio.one_wire:082]: 0x033ce10457ebb428 (DS18B20)
[05:50:42][C][gpio.one_wire:082]: 0xbc3ce1045764f628 (DS18B20)
[05:50:42][C][gpio.one_wire:082]: 0xc63ce1045730b128 (DS18B20)
[05:50:42][C][gpio.one_wire:082]: 0x233ce10457f2c528 (DS18B20)
[05:50:42][C][gpio.one_wire:082]: 0xd53ce104578cbd28 (DS18B20)
[05:50:42][C][gpio.one_wire:082]: 0x6d3ce10457dc7b28 (DS18B20)
[05:50:42][C][gpio.one_wire:082]: 0x7c3ce10457250f28 (DS18B20)
[05:50:42][C][gpio.one_wire:082]: 0xfb3ce1045776af28 (DS18B20)
[05:50:42][C][dallas.temp.sensor:029]: Dallas Temperature Sensor:
[05:50:42][C][dallas.temp.sensor:034]: Address: 0x373ce10457e4a428 (DS18B20)
[05:50:42][C][dallas.temp.sensor:035]: Resolution: 12 bits
[05:50:42][C][dallas.temp.sensor:036]: Update Interval: 10.0s
[05:50:42][C][dallas.temp.sensor:034]: Address: 0x033ce10457ebb428 (DS18B20)
[05:50:42][C][dallas.temp.sensor:034]: Address: 0xbc3ce1045764f628 (DS18B20)
[05:50:42][C][dallas.temp.sensor:034]: Address: 0xc63ce1045730b128 (DS18B20)
[05:50:42][C][dallas.temp.sensor:034]: Address: 0x233ce10457f2c528 (DS18B20)
[05:50:42][C][dallas.temp.sensor:034]: Address: 0xd53ce104578cbd28 (DS18B20)
[05:50:42][C][dallas.temp.sensor:034]: Address: 0x6d3ce10457dc7b28 (DS18B20)
[05:50:42][D][dallas.temp.sensor:054]: 'Temp_0': Got Temperature=26.3°C
[05:50:42][D][sensor:093]: 'Temp_0': Sending state 26.31250 °C with 1 decimals of accuracy
[05:50:42][C][dallas.temp.sensor:034]: Address: 0x1a3ce1045774c728 (DS18B20)
[05:50:42][C][dallas.temp.sensor:034]: Address: 0x7c3ce10457250f28 (DS18B20)
[05:50:42][C][dallas.temp.sensor:034]: Address: 0xfb3ce1045776af28 (DS18B20)
[05:50:42][C][adc:097]: ADC Sensor 'BrennerSpannung'
[05:50:42][C][adc:097]: Device Class: 'voltage'
[05:50:42][C][adc:097]: State Class: 'measurement'
[05:50:42][C][adc:097]: Unit of Measurement: 'V'
[05:50:42][C][adc:097]: Accuracy Decimals: 2
[05:50:42][C][adc:102]: Pin: GPIO17
[05:50:42][C][adc:141]: Samples: 1
[05:50:42][C][adc:142]: Update Interval: 1.0s
[05:50:42][C][captive_portal:089]: Captive Portal:
[05:50:42][C][mdns:116]: mDNS:
[05:50:42][C][mdns:117]: Hostname: tempmessung
[05:50:42][C][esphome.ota:073]: Over-The-Air updates:
[05:50:42][C][esphome.ota:074]: Address: tempmessung.local:8266
[05:50:42][C][esphome.ota:075]: Version: 2
[05:50:42][C][esphome.ota:078]: Password configured
[05:50:42][D][sensor:093]: 'BrennerSpannung': Sending state 0.13857 V with 2 decimals of accuracy
[05:50:42][C][safe_mode:018]: Safe Mode:
[05:50:42][C][safe_mode:019]: Boot considered successful after 60 seconds
[05:50:42][C][safe_mode:021]: Invoke after 10 boot attempts
[05:50:42][C][safe_mode:022]: Remain in safe mode for 300 seconds
[05:50:42][C][api:139]: API Server:
[05:50:42][C][api:140]: Address: tempmessung.local:6053
[05:50:42][C][api:142]: Using noise encryption: YES
[05:50:42][D][dallas.temp.sensor:054]: 'Temp_6': Got Temperature=51.2°C
[05:50:42][D][sensor:093]: 'Temp_6': Sending state 51.18750 °C with 1 decimals of accuracy
[05:50:43][D][sensor:093]: 'BrennerSpannung': Sending state 0.13857 V with 2 decimals of accuracy
[05:50:44][D][sensor:093]: 'BrennerSpannung': Sending state 0.13857 V with 2 decimals of accuracy
[05:50:45][D][sensor:093]: 'BrennerSpannung': Sending state 0.13857 V with 2 decimals of accuracy
[05:50:46][D][sensor:093]: 'BrennerSpannung': Sending state 0.15791 V with 2 decimals of accuracy
[05:50:47][D][sensor:093]: 'BrennerSpannung': Sending state 0.13535 V with 2 decimals of accuracy
[05:50:48][D][dallas.temp.sensor:054]: 'Temp_2': Got Temperature=26.2°C
[05:50:48][D][sensor:093]: 'Temp_2': Sending state 26.25000 °C with 1 decimals of accuracy
[05:50:48][W][component:170]: Component dallas_temp.sensor cleared Warning flag
[05:50:48][D][sensor:093]: 'BrennerSpannung': Sending state 0.14502 V with 2 decimals of accuracy
[05:50:49][W][dallas.temp.sensor:139]: 'Temp_8' - Scratch pad checksum invalid!
[05:50:49][W][component:157]: Component dallas_temp.sensor set Warning flag: scratch pad checksum invalid
[05:50:49][D][sensor:093]: 'Temp_8': Sending state nan °C with 1 decimals of accuracy
[05:50:49][D][sensor:093]: 'BrennerSpannung': Sending state 0.14502 V with 2 decimals of accuracy
[05:50:50][D][dallas.temp.sensor:054]: 'Temp_5': Got Temperature=56.1°C
[05:50:50][D][sensor:093]: 'Temp_5': Sending state 56.06250 °C with 1 decimals of accuracy
[05:50:50][D][dallas.temp.sensor:054]: 'Temp_9': Got Temperature=55.1°C
[05:50:50][D][sensor:093]: 'Temp_9': Sending state 55.06250 °C with 1 decimals of accuracy
[05:50:50][D][sensor:093]: 'BrennerSpannung': Sending state 0.14824 V with 2 decimals of accuracy
[05:50:50][D][dallas.temp.sensor:054]: 'Temp_4': Got Temperature=18.8°C
[05:50:50][D][sensor:093]: 'Temp_4': Sending state 18.75000 °C with 1 decimals of accuracy
[05:50:51][D][dallas.temp.sensor:054]: 'Temp_1': Got Temperature=41.1°C
[05:50:51][D][sensor:093]: 'Temp_1': Sending state 41.12500 °C with 1 decimals of accuracy
[05:50:51][D][dallas.temp.sensor:054]: 'Temp_3': Got Temperature=25.7°C
[05:50:51][D][sensor:093]: 'Temp_3': Sending state 25.68750 °C with 1 decimals of accuracy
[05:50:51][D][sensor:093]: 'BrennerSpannung': Sending state 0.13213 V with 2 decimals of accuracy
[05:50:51][D][dallas.temp.sensor:054]: 'Temp_7': Got Temperature=33.6°C
[05:50:51][D][sensor:093]: 'Temp_7': Sending state 33.62500 °C with 1 decimals of accuracy
[05:50:52][D][dallas.temp.sensor:054]: 'Temp_0': Got Temperature=26.3°C
[05:50:52][D][sensor:093]: 'Temp_0': Sending state 26.31250 °C with 1 decimals of accuracy
[05:50:52][D][sensor:093]: 'BrennerSpannung': Sending state 0.14502 V with 2 decimals of accuracy
[05:50:52][D][dallas.temp.sensor:054]: 'Temp_6': Got Temperature=51.2°C
[05:50:52][D][sensor:093]: 'Temp_6': Sending state 51.18750 °C with 1 decimals of accuracy
Here is the code and log from Device B (Temp display):
esphome:
friendly_name: Badezimmer
esp8266:
board: esp01_1m
# Enable logging
logger:
api:
encryption:
key: "iI1tfBIStTkLKKiqh6ivxqPvjM3gOvPCdiBRCntUac8="
ota:
- platform: esphome
password: "62d4d7e381a40ed19688beaf06b1752a"
wifi:
ap:
ssid: "Badezimmer Fallback Hotspot"
password: "uTB0wSAx9dzi"
captive_portal:
- platform: homeassistant
entity_id: sensor.tempmessung_temp_6
state_class: "measurement"
#sensor:
# - platform: template
# name: "Fixed Temp"
# id: temp_6_display
# lambda: |-
# return 42;
display:
platform: tm1637
clk_pin: GPIO14
dio_pin: GPIO12
inverted: true
length: 4
lambda: |-
it.printf(0, "%2.1f", id(temp_6_display).state);
ESP_LOGD("Temp_6: ", "Current Temp: %2.1f", temp_6_display);
INFO Reading configuration /config/esphome/badezimmer.yaml...
INFO Starting log output from 192.168.0.123 using esphome API
INFO Successfully connected to badezimmer @ 192.168.0.123 in 0.005s
INFO Successful handshake with badezimmer @ 192.168.0.123 in 2.403s
[05:53:48][I][app:100]: ESPHome version 2024.9.2 compiled on Nov 18 2025, 05:43:17
[05:53:48][C][wifi:600]: WiFi:
[05:53:48][C][wifi:428]: Local MAC: A4:CF:12:EE:BC:93
[05:53:48][C][wifi:433]: SSID: [redacted]
[05:53:48][C][wifi:436]: IP Address: 192.168.0.123
[05:53:48][C][wifi:439]: BSSID: [redacted]
[05:53:48][C][wifi:441]: Hostname: 'badezimmer'
[05:53:48][C][wifi:443]: Signal strength: -66 dB ▂▄▆█
[05:53:48][C][wifi:447]: Channel: 1
[05:53:48][C][wifi:448]: Subnet: 255.255.255.0
[05:53:48][C][wifi:449]: Gateway: 192.168.0.1
[05:53:48][C][wifi:450]: DNS1: 192.168.0.1
[05:53:48][C][wifi:451]: DNS2: 0.0.0.0
[05:53:48][C][logger:185]: Logger:
[05:53:48][C][logger:186]: Level: DEBUG
[05:53:48][C][logger:188]: Log Baud Rate: 115200
[05:53:48][C][logger:189]: Hardware UART: UART0
[05:53:48][C][display.tm1637:138]: TM1637:
[05:53:48][C][display.tm1637:139]: Intensity: 7
[05:53:48][C][display.tm1637:140]: Inverted: 1
[05:53:48][C][display.tm1637:141]: Length: 4
[05:53:48][C][display.tm1637:142]: CLK Pin: GPIO14
[05:53:48][C][display.tm1637:143]: DIO Pin: GPIO12
[05:53:48][C][display.tm1637:144]: Update Interval: 10.0s
[05:53:48][C][captive_portal:089]: Captive Portal:
[05:53:48][C][mdns:116]: mDNS:
[05:53:48][C][mdns:117]: Hostname: badezimmer
[05:53:48][C][esphome.ota:073]: Over-The-Air updates:
[05:53:48][C][esphome.ota:074]: Address: badezimmer.local:8266
[05:53:48][C][esphome.ota:075]: Version: 2
[05:53:48][C][esphome.ota:078]: Password configured
[05:53:48][C][safe_mode:018]: Safe Mode:
[05:53:48][C][safe_mode:019]: Boot considered successful after 60 seconds
[05:53:48][C][safe_mode:021]: Invoke after 10 boot attempts
[05:53:48][C][safe_mode:022]: Remain in safe mode for 300 seconds
[05:53:48][C][api:139]: API Server:
[05:53:48][C][api:140]: Address: badezimmer.local:6053
[05:53:48][C][api:142]: Using noise encryption: YES
[05:53:48][C][homeassistant.sensor:030]: Homeassistant Sensor 'temp_6_display'
[05:53:48][C][homeassistant.sensor:030]: State Class: 'measurement'
[05:53:48][C][homeassistant.sensor:030]: Unit of Measurement: '°C'
[05:53:48][C][homeassistant.sensor:030]: Accuracy Decimals: 1
[05:53:48][C][homeassistant.sensor:031]: Entity ID: 'sensor.tempmessung_temp_6'
[05:53:51][D][Temp_6: :055]: Current Temp: 1.9
[05:54:01][D][Temp_6: :055]: Current Temp: 1.9
It didnt work the display shows “nAn” and the displayed value in the log shows 1,9 °C …
What do i wrong here ?
Best regards
Kai
