Measuring water level with a Digital pressure sensor
Hi All,
I’m currently looking to monitor water levels in a Stormsaver 7500l Tank using a HX710B based sensor with most likely a PSG010S fitted
The tank has approximately 1m level when full, so approximately 10KPa. Has anyone used such a setup before, I can’t see any reference on this forum. If not i will post my findings here over the next few months, as i feel it should be more reliable than the ultrasonic distance method over a few years
To reply to my own question, it may be that the hx711 integration is close enough to use out of the box, or be reworked and merged into the upstream for support. Time will tell when I receive the modules for testing.
