Media Browser Entity not Found
I have 3 Home assistants in two of my homes (I have to work away from my ‘real’ home ie 2500Kms away).
So setup a Pi4 in the home where I work. And I have a X86 i7 system plus a Pi3 with Remote Home assistant installed. As I understand I can only have one Zigbee Coordinator per HAOS system.
Problem-
I can’t get the X86 i7 system to run the media Browser , but the Pi3 at the same location dose not have this issue. It’s like the X86 HAOS can’t ‘see’ the Google Assistant speakers. But from the ‘Overview’ I can tune ON a particular Speaker. But not select Media to play, I keep getting this error -
Media Browsing Error
Entity not found
any idea’s on where I should look to fix this ?
regards,
Stephen
so far I’ve tried to delete the Google Cast Device entry. And reboot, which causes this entiry to get ‘found again’ and the speakers, chromecats etc all get re-added back.
But this has not resolved this issue. It looks or seems to me that all the enterys for ‘local media’, DLNA services, Web radio statitiosn etc all seem to be missing.
Will look to see if I can find which service provides this.
regards,
Stephen
Well think I’ve fixed it. I found the the Spotify integration was ‘disabled’. Turning this ON, has now fixed the Browser Error. Suspect this is a BUG. But I want the Spoitfy enabled anyhow and not sure when (i) or how ever it got shutdown.
Stephen.
