So i’m using Sonos in my home. Via ESPHome i’m trying to use media_player.join Home Assistant service call to join a speaker, but it does not seem to work when i try to use:
- homeassistant.service:
service: media_player.join
group_members: media_player.sonos_zolder
entity_id:
- media_player.sonos_woonkamer
i get [target] is an invalid option for [homeassistant.service]. Please check the indentation.
But i think the indentation is good, or am i missing something simple here?
This does work when i use it in Home Assistant itself.
That doesn’t seem to work either.
Then i get “Must be string, got <class ‘esphome.helpers.OrderedDict’>. did you forget putting quotes around the value?.”
INFO Reading configuration /config/esphome/d1_mini_socket_attic_balcony.yaml...
Failed config
binary_sensor.gpio: [source /config/esphome/d1_mini_socket_attic_balcony.yaml:31]
platform: gpio
pin:
number: D6
mode: INPUT_PULLUP
inverted: True
name: Socket Touch Button Attic Balcony
on_click:
- min_length: 50ms
max_length: 350ms
then:
- switch.toggle: socket_relay_attic_balcony
- min_length: 500ms
max_length: 5s
then:
service: media_player.volume_set
entity_id: media_player.sonos_zolder
volume_level: 0.10
Must be string, got <class 'esphome.helpers.OrderedDict'>. did you forget putting quotes around the value?.
entity_id:
- media_player.sonos_zolder
- logger.log: Sonos Zolder Geactiveerd
fastcolors
(Fastcolors)
December 21, 2022, 8:50pm
5
did You ever get to solve this?
I had the same error this this code:
service: light.toggle
data: {}
entity_id: light.tira_led_entrada
but thisone is working:
