Media_player.template
Good day ToR,
No i just followed the instructions in the first post.
How to install:
  1. Create a ‘custom_components’ folder in your config folder(if it doesn’t exist)
  2. Create ‘template’ folder in the custom_components folder
  3. Copy all the file from https://github.com/home->assistant/core/tree/dev/homeassistant/components/template to this folder (I read that this is needed otherwise the component isn’t overriden)
  4. Copy my media_player.py to this folder
Ok, the installation text is a little confusing for a newbie.
I installed the the Integration with HACS and did the Installation instructions i mentioned in the precious text.
#Media Player Template
media_player:
  • platform: template
    media_players:
    playstation_5:
    device_class: tv
    unique_id: media_player.playstation_5
    friendly_name: “PS5”
    media_image_url_template: >
    {% if states(‘sensor.nick_s_ps5_activity’) == “playing” %}
    {{ state_attr(‘sensor.nick_s_ps5_activity’,‘title_image’) }}
    {% endif %}
    turn_off:
    data_template:
    entity_id: sensor.nick_s_ps5_activity
    service: switch.turn_off
    turn_on:
    data_template:
    service: switch.turn_on
    current_source_template: “{{ state_attr(‘sensor.nick_s_ps5_activity’,‘title_name’) }}”
    value_template: “{{ states(‘sensor.nick_s_ps5_activity’) }}”
    title_template: “{{ state_attr(‘sensor.nick_s_ps5_activity’,‘title_name’) }}”
but I’m getting an error:
Error loading /config/configuration.yaml: while parsing a block mapping
in “/config/configuration.yaml”, line 23, column 9
expected , but found ‘’
in “/config/configuration.yaml”, line 37, column 10
those lines are:
device_class: tv
and
Hi @fitsou,
Seems like you have a problem with how your YAML is formatted.
It could be one of the following:
  1. Indentation Issues: YAML relies heavily on correct indentation. Make sure that you use spaces (not tabs) for indentation and that your indentation is consistent throughout the file.
  2. Missing Colon: Each key-value pair should be separated by a colon. If you forget to include a colon after a key, you’ll encounter this error.
  3. Incorrect Spacing: Ensure that there is proper spacing around colons and that key-value pairs are aligned correctly.
  4. Incorrect Nesting: If you’re defining lists or dictionaries (nested structures), make sure they are indented properly and nested at the correct level.
  5. Missing or Extra Characters
Please avoid posting code with “Blockquote” since it makes it impossible to see any formatting errors. Instead use the “Preformatted text”. You can post in-line or multi-line code using that.
I just installed your templated to solve a pretty tricky problem. it is working pretty good so far except…
the number one reason I am installing this is to create a “now playing” entity that will store media_artist, media_album and most important entity_picture. I have set the entity_picture value to:
    entity_picture_template: "{{ states('input_text.music_current_album_art') }}"
I don’t get any errors in the yaml configuration.
Even when there is a value for “{{ states(‘input_text.music_current_album_art’) }}”, the entity_picture isn’t showing up… here is the output from my developer tools screen:
source_list: source 1, source 2
media_title: Under the Bridge
media_artist: Red Hot Chili Peppers
entity_picture_local: null
device_class: speaker
friendly_name: Now Playing
supported_features: 68992
media_position_updated_at: 2023-08-21T12:15:00.511097+00:00
The whole yaml configuration I created is:
media_player:
  • platform: media_player_template
    media_players:
    now_playing:
    value_template: >
    {% if is_state(“input_boolean.music_playing”, “on”) -%}
    playing
    {%- else -%}
    idle
    {%- endif %}
    turn_on:
    data_template:
    entity_id: switch.receiver_on
    turn_off:
    data_template:
    entity_id: switch.receiver_off
    volume_up:
    data_template:
    entity_id: switch.volume_up
    volume_down:
    data_template:
    inputs:
    source 1:
    service: input_boolean.turn_on
    data_template:
    entity_id: input_boolean.source_1
    source 2:
    data_template:
    entity_id: input_boolean.source_2
    entity_picture_template: “{{ states(‘input_text.music_current_album_art’) }}”
    title_template: “{{ states(‘input_text.currenttitle’) }}”
    artist_template: “{{ states(‘input_text.currentartist’) }}”
Is entity_picture supported? If so, Am I doing something wrong in the above configuration?
Thanks in advance
please paste your code in preformatted text to make it readable.
it should look like this:
switch:
    switches:
      sony_tv:
        value_template: "{{ is_state('remote.sony_kd_65x89j', 'on') }}"
        turn_on:
          service: remote.turn_on
            entity_id: remote.sony_kd_65x89j
        turn_off:
          service: remote.turn_off
you need the sources for image url, artist name etc to define in your template.
maybe this might help you?
        title_template: |-
          {%- if is_state("sensor.avr_source", "Google TV") -%}
            {%- if states.media_player.spotify_tor.attributes.source is defined and states.media_player.spotify_tor.attributes.media_title is defined%}
              {%- if is_state_attr("media_player.spotify_tor",'source', 'Google TV 4K') and is_state('media_player.spotify_tor','playing') -%}
                {%- set media_title = states.media_player.spotify_tor.attributes.media_title -%}
                {%- set media_album_name = states.media_player.spotify_tor.attributes.media_album_name -%}
                {%- if media_title == media_album_name -%}
                  {{media_title}}
                {%- else -%}
                  {{media_title}} ({{media_album_name}})
                {%- endif %}
              {%- endif -%}
            {%- else -%}
              {% if states.media_player.google_tv_4k.attributes.media_title is defined %}
                {{states.media_player.google_tv_4k.attributes.media_title}}
              {%- else -%}
                {{states.media_player.google_tv_4k.attributes.app_name}}
              {%- endif -%}
            {%- endif -%}
          {%- elif is_state("sensor.avr_source", "FM Tuner") -%}
            {{states.number.avr_tuner_frequency.state}}
            {%- set prst = states.number.avr_tuner_preset.state|int -%}
            {%- if prst == 1 -%}: TRT 3{%- endif -%}
            {%- if prst == 2 -%}: CNN Türk{%- endif -%}
            {%- if prst == 3 -%}: Bloomberg{%- endif -%}
            {%- if prst == 4 -%}: TRT 1{%- endif -%}
            {%- if prst == 5 -%}: Lounge FM{%- endif -%}
            {%- if prst == 6 -%}: Eksen{%- endif -%}
            {%- if prst == 7 -%}: Metro{%- endif -%}
            {%- if prst == 8 -%}: RS FM{%- endif -%}
            {%- if prst == 9 -%}: TRT Haber{%- endif -%}
            {%- if prst == 10 -%}: Power FM{%- endif -%}
            {%- if prst == 11 -%}: Fenomen{%- endif -%}
            {%- if prst == 12 -%}: Ulusal Radyo{%- endif -%}
            {%- if prst == 13 -%}: TRT Nağme{%- endif -%}
            {%- if prst == 14 -%}: Number 1{%- endif -%}
            {%- if prst == 15 -%}: PAL FM{%- endif -%}
            {%- if prst == 16 -%}: Radyo Voyage{%- endif -%}
          {%- else -%}
            {{states.media_player.str_dn1080_2.attributes.media_title}}
          {%- endif -%}
        # Sub Title (regular) ---
        artist_template: |-
            {%- if states.media_player.spotify_tor.attributes.source is defined %}
                {{states.media_player.spotify_tor.attributes.media_artist}}
              {%- endif -%}
            {%- else -%}
              {% if states.media_player.google_tv_4k.attributes.media_artist is defined %}
                {{states.media_player.google_tv_4k.attributes.media_artist}}
              {%- else -%}
                {%- endif -%}
              {%- endif -%}
            {%- endif -%}
            FM Tuner
          {%- else -%}
            {{states.media_player.str_dn1080_2.attributes.media_artist}}
          {%- endif -%}
        # Hidden Title ---
        album_template: |-
                {{states.media_player.spotify_tor.attributes.media_album_name}}
              {%- endif -%}
            {%- else -%}
              {% if states.media_player.google_tv_4k.attributes.media_album_name is defined %}
                {{states.media_player.google_tv_4k.attributes.media_album_name}}
              {%- else -%}
                {% if states.media_player.google_tv_4k.attributes.app_name is defined %}
                {%- else -%}
                  {{states.media_player.google_tv_4k_adb.attributes.source}}
                {%- endif -%}
              {%- endif -%}
            {%- endif -%}
          {%- else -%}
            {%- if states('media_player.str_dn1080_2')=='playing' -%}{{states.media_player.str_dn1080_2.attributes.media_album_name}}{%- endif -%}
          {%- endif -%}
        media_content_type_template: |-
            music
            music
          {%- else -%}
            {{states.media_player.str_dn1080_2.attributes.media_content_type}}
          {%- endif -%}
        media_image_url_template: |-
            {% if states.media_player.google_tv_4k.attributes.entity_picture is defined %}
              {{states.media_player.google_tv_4k.attributes.entity_picture}}
            {%- else -%}
                  {{states.media_player.spotify_tor.attributes.entity_picture}}
                {%- endif -%}
              {%- else -%}
                {{states.media_player.google_tv_4k_adb.attributes.entity_picture}}
              {%- endif -%}
            {%- endif -%}
          {%- else -%}
            {{states.media_player.str_dn1080_2.attributes.entity_picture}}
          {%- endif -%}
Sorry, didn’t see that it came over with lack formatting. Here it is again:
media_player:
  - platform: media_player_template
    media_players:
      now_playing:
        value_template: >
          {% if is_state("input_boolean.music_playing", "on") -%}
            playing
          {%- else -%}
            idle
          {%- endif %}
        turn_on:
          data_template:
        turn_off:
          data_template:
        volume_up:
          data_template:
        volume_down:
          data_template:
        inputs:
          source 1:
            data_template:
          source 2:
            data_template:
        title_template: "{{ states('input_text.currenttitle') }}"
        album_template: "{{ states('input_text.currentalbum') }}"
        artist_template: "{{ states('input_text.currentartist') }}"
Thanks for responding.
If you mean by source, another media player’s entity, artist, etc… that is what I am trying to avoid. Instead of using a Universal Media player template, I am using this so I can put my own values in such as text variables. I am using multiple media players to create a now-playing media player. I am putting the artist, title, entity_picture I need to use in text helpers. The Artis, album, title is working. the one one not working is the entity_picture.
Taking another screenshot of what developer tools shows for the output of above:
media_title: — Waiting For Next Selection —
media_artist: — You —
media_album_name: unknown
entity_picture_local: /api/media_player_proxy/media_player.now_playing?token=f97a2d51c9094baedfbad3425ec07513d30eb9f6f30a5de42355322762c8fd73&cache=24469974c13ad996
It appears to create an entity_picture_local field - possibly from my url that I supplied in entity_picture_template. This does work for
My need is to actually have the entity_picture entry in place. I am using a different user interface for my UI (sharptools.io). I have been liking the layout of this for my console better than Lovelace (without sever work). Sharptools takes a media player, and it it appears that it is using the entity_picture (not the local one for album art.
you know entity picture is just an icon sized picture inplace of the icons right?
this is entity_picture:
I’m not sure media_player.template supports templating entity_picture.
However you can template media_image_url_template which looks like this:
yes the media_player.template shows an entity_picture in the states but it’s media_image_url_template.
you can use custom:mini-media-player to make it appear like mine.
or use the media-control card.
thank you for all of your recommendations. Again, I am not trying to use Lovelace media player. I am using a different 3rd party tool for my dashboard (sharptools.io).
I found a work-around. It appears that I can write the value of the entity_picture into the now_playing media player later in an automation, using python, like this:
service: python_script.hass_entity
  action: set_attributes
  entity_id: media_player.now_playing
  attributes:
    - entity_picture: "{{ states('input_text.music_current_album_art') }}"
This carries the value of the entity_picture over to sharptools and appears to be working
Thank you very much for your help.
Ok i’m sending the code in preformatted text, cause I’m unable to find the error.
media_player:
    media_players:
      playstation_5:
        device_class: tv
        friendly_name: "PS5"
          {% if states('sensor.nick_s_ps5_activity') == "playing" %}
           {{ state_attr('sensor.nick_s_ps5_activity','title_image') }}
          {% endif %}
        turn_off:
          data_template:
        turn_on:
          data_template:
        current_source_template: "{{ state_attr('sensor.nick_s_ps5_activity','title_name') }}"
        value_template: "{{ states('sensor.nick_s_ps5_activity') }}"
        title_template: "{{ state_attr('sensor.nick_s_ps5_activity','title_name') }}"
Platform error media_player.template - No module named 'homeassistant.components.template.media_player'
The platform is not template but media_player_template
ok i make it work. but i do not get the image of the game, it just changes the background color of playstation media template.
I don’t think your issue is specific to the media_player.template.
look at the following as an example. All four cards use the same media_player entity.
type: vertical-stack
title: Spotify Player
cards:
  - type: entities
    entities:
      - entity: media_player.spotify_tor
  - type: custom:mini-media-player
  - type: media-control
    artwork: full-cover
    tap_action: none
    toggle_power: false
    hide:
      icon: true
      info: true
      power: true
      source: true
      sound_mode: true
      controls: true
      prev: true
      next: true
      play_pause: true
      play_stop: true
      jump: true
      volume: true
      volume_level: true
      mute: true
      progress: true
      runtime: true
      runtime_remaining: true
      artwork_border: true
      power_state: true
      icon_state: true
      shuffle: true
      repeat: true
      state_label: true
and this is how these look:
Thanks for replying.
There is some delay some times in showing the artwork from PlayStation. Ι cannot pinpoint when this delay is happening. but I can live with it.
Now I’m trying to have my Sony Bravia TV to show the artwork of the movie/series from the apps (Netflix, Disney, Plex, etc)
Got it to work with my Nintendo Switch, like I did with my PS5:
PS5HA
botw
    media_players:
      nintendo_switch:
        device_class: tv
        unique_id: media_player.nintendo_switch
        friendly_name: "Switch"
        media_image_url_template: "{{ state_attr('sensor.nintendo_switch_activity','imageUri') }}"
        turn_off:
          data_template:
            entity_id: switch.nintendo_switch
        turn_on:
          data_template:
        volume_up:
          service: media_player.volume_up
          data_template:
            entity_id: media_player.onkyo
        volume_down:
          service: media_player.volume_down
          data_template:
        mute:
          service: media_player.mute
          data_template:
        inputs:
          Onkyo:
            service: media_player.select_source
            data_template:
              source: "game"
          TV:
            data_template:
              entity_id: media_player.lg55b6v
              source: "Onkyo"
        current_source_template: "{{ states('input_text.selected_source') }}"
        value_template:  >
          {% if is_state("sensor.nintendo_switch_activity", "ONLINE") -%}
            on
          {%- else -%}
            off
          {%- endif %}
        title_template: "{{ state_attr('sensor.nintendo_switch_activity','name') }}"
You can create something similar using a custom button card.
