From here I am trying to remove some room.
eg, I have ground floor with garage and a winter garden.
I managed to remove single entities from the calculation like this:
{{ floor_areas("Rez")
| map('area_entities')
| sum(start=[])
| select('is_state_attr', 'device_class', 'temperature')
| reject('eq', 'sensor.rez_verranda_th_temperature')
| map('states')
| select('is_number')
| map('float')
| average }}
But to be more robust I would like to do it per room and I am stuck here:
| sum(start=[])
| reject('entity_id', 'in', area_entities('veranda') + area_entities('garage') )
| map('states')
| select('is_number')
| map('float')
| average }}
Inspired from this topic:
