MediaPlayers don't play after upgrading to 2022.3
After upgrading Home Assistant (Hassio) from 2022.2.9 to 2022.3.0 (but i tried also 2022.3.1) all my google (mini and nest) media players don’t play anymore.
I went back to 2022.2.9 and they play again.
I found in the log of 2022.3x the error
2022-03-04 12:53:23 ERROR (Thread-10) [homeassistant.components.cast.media_player] Failed to cast media https://192.168.188.16:8123/media/local/sound.mp3?authSig=xxx from internal_url (https://192.168.188.16:8123). Please make sure the URL is: Reachable from the cast device and either a publicly resolvable hostname or an IP address
The problem is that ip addres doesn’t exist anymore. It was my ip address when I used the wifi connection but it’s more than year that I use lan.
I checked in all configuration files and that ip address there isn’t.
Someone knows where it could be stored?
Thanks,
Maurizio.
I had set the new ip in internal_url of configuration.yaml but there was the old one in general → internal url.
Evidently in the previous versions HA did not use it while now it does.
