Medicines Sensor?
Hi All,
Yep, I’m very new to HA and would like some help.
Firstly I am disabled and partially sighted so reading masses of confusing documents is painful.
I am trying to add a Notice / Area ? that tells me when my medications are about to run out.
I have created a basic Sqlite3 table that contains the columns:
Med_Name
Pack_Quantity
Updated_Date
Daily_Dose
I know I need to Divide Pack_Quantity / Daily_Dose to get the number of days till I run out of that particular drug.
I then need to add that to the Updated_Date to get the actual date the drug will run out.
Also if I subtract 7 from the actual date that will give me 7 days to obtain a new pack. 7 Days is the maximum the Pharmacy will alllow on some of the drugs.
I created a test sensor in configuration.yaml
    sensors:
      julian_fudge_sensor:
        friendly_name: "Julian's Fudge Sensor"
        value_template: "{{ 1234 }}"
        unit_of_measurement: "units"
        unique_id: fudge_sensor
This proves I can at least create and display a sensor.
My question is do I make a python script that interrogates the Sqlite table and calculates the information that I need or directly interrogate the Sqlite db and configure the return values, push the date to MQTT and pull it from there?
Whichever is the better solution how do I create the template ? With all of the code in it {{ }} or in a file and pass the data to the template {{ }} ?
If someone could please indicate how to proceed I will be indebted.
Thank you and kind regards,
jB :sunglasses:
How many different medicines are you looking to track ?
If its not hundreds, perhaps use HA’s helpers to store the data instead, then its trivial to create templates which days until you run out.
I would also choose a mentioned way “use HA helpers”.
Assume you have 5 input helpers for those parameters.
Then assume you have some amount of template sensors (one per a medicine):
state - some most important parameter,
attributes - equal to those helpers.
These sensors would have same structure but using different helpers as source.
And you may display these template sensors in a table-like card (custom flex-table-card, stock Markdown).
You may even have one helper per a parameter, not for every medicine. And some input_select helper (filled with names of medicines) may be used to select which particular template sensor should be updated when a parameter’s helper is changed.
And automations tracking a particular attribute for all medicines’ template sensors will alert you about necessary actions.
Hope my explanations are clear.
Thank you both for your input.
As you both agree that helpers is the way to go, I will try and see what I can pull up using helpers.
If it all works I will report back.
Many thanks and kind regards.
jB😎
