MELcloud temperature limits
Hello! Is it possible for one to change the temperature extremes that are allowable in the Climate card created by the integration? I use a number of Air-to-Air heat pump indoor units (one outdoor unit) and with the MelCloud App I can set temperatures up to 31 C and down to 10 C. But the integration in Home Assistant I can only set up to 24 C and down to 19 C. If there was an option for me to set this when setting up the integration, I may have done that. But now I want to change it mostly because the temperature sensing of the units is so bad it is better to use an external thermostat and set the unit itself higher than I actually want the room temperature.
Thank you.
ps - I cannot submit a bug report on the github page for reasons unknown
