Memory leakage when using remote access / remote GUI from Nabu Casa
Hallo,
I have a 0.90.1 instance running under Hasbian on a Raspberry Pi. Everything runs fine, but when I use the new feature remote gui via de url https://abcdefghijklmn.ui.nabu.casa, I imediately see an increase in memory sage of the Home Assistant process, eventually resulting in out of memory crashes.
After starting the Remote UI, the memory use rises from 23% to 60% within 5 minutes and continues untill it crashes with an out-of memory error.
When I close the http connection to the Remote UI the memory sage drops again.
This proces is reproducable. Any one else experiencing the Same Problem?
With kind regards,
Remco
