Merging multiple iOS action automations into one
Hey,
I have four working iOS actions setup. Each iOS action triggers it’s own automation. So four actions, four automations. I have this bright idea to clean things up by combining all four into one using something like “choose”. Because of how the triggers are setup I’m not sure how I would incorporate them into something like “choose”. I’m not stuck on using choose if someone wants to make a suggestion.
Current working automation for single action.
triggers:
  - event_type: ios.action_fired
    event_data:
      actionName: front_door_lock
    trigger: event
actions:
  - if:
      - condition: state
        entity_id: lock.front_door
        state:
          - locked
    then:
      - action: lock.unlock
        metadata: {}
        data: {}
    else:
      - action: lock.lock
        metadata: {}
        data: {}
This is gonna be a syntax mess with wrong spacing everywhere. I just whipped it up to give an idea as to where I want to go. I’m just not sure how I can incorporate the ios action as a condition to action on. I only know how to do it as a trigger.
triggers:
    event_data:
    trigger: event
    event_data:
      actionName: back_door_lock
    trigger: event
actions:
  - choose:
    -  alias: Front door
       conditions:
           event_data:
           trigger: event
         sequence:
           if:
             - condition: state
               state:
                 - locked
          then:
          else:
             - action: lock.lock
    -  alias: Back door
       conditions:
           event_data:
           trigger: event
         sequence:
           if:
             - condition: state
               entity_id: lock.back_door
               state:
                 - locked
          then:
          else:
             - action: lock.lock
