Meross MSG100 Help
So i replaced my Aladdin connect with a Meross MSG100
i have it connected to HA using Meross_Lan but my automation for garage door open and closed no longer work when i check the state it matches the automation has any had this issue
also not using local mqtt (no android device to do so with)
hi, does the garage door open and close through the meross app ? Does the door open / close through the controls within HA?
Assuming your automation used the old aladdin, I would delete the open and close steps in your automation and create new ones using the meross open/close control.
