I will start with I don’t know much about docker. I have installed docker on an existing Ubuntu server and have been running HA/Supervisor for a few weeks with no issues. Long story short, I was troubleshooting something else and during that I shut down all containers via docker stop $(docker ps -q). I did not know that I should not have done that, nor did I get a list of images running before I stopped them. Now I can’t seem to start the containers. I ran docker images but when I try to start the images using the listed ID’s none of them will start. I found the command:
docker run -d --name=“home-assistant” -v /PATH_TO_YOUR_CONFIG:/config -v /etc/localtime:/etc/localtime:ro --net=host homeassistant/home-assistant:stable
but I don’t know what the PATH_TO_YOUR_CONFIG should be. Any pointers? Or am I screwed?
Thanks to you both, I’ll setup portainer. Sometimes it seems that docker is almost too easy, so I’ve skipped getting into it too deeply, I’ll definitely educate myself.
