I messed up my MQTT broker and now its not accepting the config via the add-on.
2018-12-23 16:35:36 WARNING (MainThread) [homeassistant.components.mqtt] Data in your config entry is going to override your configuration.yaml: {‘broker’: ‘core-mosquitto’, ‘discovery’: True, ‘password’: ‘zBNajZfUM1xafmKbkbeugu2N-KS-5dhh’, ‘port’: 1883, ‘protocol’: ‘3.1.1’, ‘username’: ‘homeassistant’}
2018-12-23 16:35:37 ERROR (Thread-2) [homeassistant.components.mqtt] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2018-12-23 16:35:37 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Mosquitto broker for mqtt
File “/usr/local/lib/python3.6/site-packages/homeassistant/config_entries.py”, line 249, in async_setup
result = await component.async_setup_entry(hass, self)
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/mqtt/init.py”, line 554, in async_setup_entry
hass, conf, hass.data[DATA_MQTT_HASS_CONFIG], entry)
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/mqtt/init.py”, line 366, in _async_setup_discovery
config_entry) # type: bool
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/mqtt/discovery.py”, line 260, in async_start
hass, discovery_topic + ‘/#’, async_device_message_received, 0)
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/mqtt/init.py”, line 306, in async_subscribe
topic, msg_callback, qos, encoding)
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/mqtt/init.py”, line 688, in async_subscribe
await self._async_perform_subscription(topic, qos)
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/mqtt/init.py”, line 723, in _async_perform_subscription
_raise_on_error(result)
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/mqtt/init.py”, line 808, in _raise_on_error
‘Error talking to MQTT: {}’.format(mqtt.error_string(result_code)))
homeassistant.exceptions.HomeAssistantError: Error talking to MQTT: The client is not currently connected.
[INFO] Setup mosquitto configuration
[WARN] SSL not enabled - No valid certs found!
[INFO] Found local users inside config
[INFO] Initialize system configuration.
[INFO] Initialize Hass.io Add-on services
[INFO] Initialize Home Assistant discovery
[INFO] Start Mosquitto daemon
1545575610: mosquitto version 1.4.15 (build date 2018-03-04 15:35:59+0000) starting
1545575610: Config loaded from /etc/mosquitto.conf.
1545575610: *** auth-plug: startup
1545575610: ** Configured order: http
1545575610: Opening ipv4 listen socket on port 1883.
1545575610: Opening ipv6 listen socket on port 1883.
1545575610: Opening websockets listen socket on port 1884.
1545575610: Warning: Mosquitto should not be run as root/administrator.
1545575616: New connection from 192.168.0.108 on port 1883.
[INFO] found admin on local database
1545575616: New client connected from 192.168.0.108 as sonoff3 (c1, k15, u’admin’).
1545575616: New connection from 192.168.0.105 on port 1883.
1545575616: New client connected from 192.168.0.105 as sonoff (c1, k15, u’admin’).
1545575616: New connection from 192.168.0.19 on port 1883.
1545575617: New client connected from 192.168.0.19 as sonoff5 (c1, k15, u’admin’).
1545575620: New connection from 192.168.0.106 on port 1883.
1545575621: New client connected from 192.168.0.106 as sonoff1 (c1, k15, u’admin’).
1545575621: New connection from 192.168.0.107 on port 1883.
1545575621: New client connected from 192.168.0.107 as sonoff2 (c1, k15, u’admin’).
1545575652: New connection from 192.168.0.107 on port 1883.
1545575652: Client sonoff2 already connected, closing old connection.
1545575652: Client sonoff2 disconnected.
1545575652: New client connected from 192.168.0.107 as sonoff2 (c1, k15, u’admin’).
1545575683: Socket error on client sonoff2, disconnecting.
1545575683: New connection from 192.168.0.107 on port 1883.
1545575683: New client connected from 192.168.0.107 as sonoff2 (c1, k15, u’admin’).
1545575715: New connection from 192.168.0.107 on port 1883.
1545575715: Client sonoff2 already connected, closing old connection.
1545575715: Client sonoff2 disconnected.
1545575715: New client connected from 192.168.0.107 as sonoff2 (c1, k15, u’admin’).
1545575736: New connection from 172.30.32.1 on port 1883.
[WARN] Not found homeassistant on local database
1545575737: Socket error on client , disconnecting.
1545575746: New connection from 192.168.0.107 on port 1883.
1545575746: Client sonoff2 already connected, closing old connection.
1545575746: Client sonoff2 disconnected.
1545575746: New client connected from 192.168.0.107 as sonoff2 (c1, k15, u’admin’).
