Met.no - monitored_conditions
How could I get the temperature and pressure values of the met.no weather info.
I know, how to do this for openweathermap, but not for met.no
  - platform: openweathermap
    api_key: 3153546563254245245252525
    monitored_conditions:
      - temperature
      - humidity
      - pressure
platform: met or met.no seems not to work…
And this template neither
  -platform: template
    sensors:
      met_no_temperature:
        friednly_name: "hajo"
        unit_of_measurement: 'degree'
        value_template: "{{ state_attr('weather.cologne', 'temperature') }
i don’t have an answer. but please tell me you’ve not shared your actual API_Key.
If so, make sure to change it / request a new one.
Just check the doc and it does not state how to monitor specific conditions, it does state however that
Configuration of the Met.no platform via configuration.yaml is deprecated from version 0.95
To add Met.no to your installation, go to Configuration » Integrations in the UI and enable the Met.no integration. By default the values will be taken from the Home Assistant configuration.
No :grinning: Just some numbers.
It’s enabled…
  sensors:
      weather_temp:
        friendly_name: "Weather Temperature"
        unit_of_measurement: '°C'
        value_template: "{{ state_attr('weather.home', 'temperature') }}"
Check states page to check the name of your weather entity :slight_smile:
Edit: sorry it’s for the new met.no component
Regards
  sensors:
      weather_wind_direction:
        friendly_name: "Weather Wind Direction"
        unit_of_measurement: '°'
        value_template: "{{ state_attr('weather.home', 'wind_bearing') }}"
This for wind direction?
Also me unable to find Met in integration page…I’m unable to use Met.no sensors…I didn’t find any documentation howto use it
