In Scotland the “feels like” temperature is often very different from the actual or forecasted temp. Would it be possible to add a “feels like” forecast entity (as I assume the current daily & 3 hourly forecast can only have 1 attribute for each time entry) ?
Also I notice from an old android app that you can get hourly data for the first 48 hours then 3 hourly for the next 72 from the api. Could we add the option to get the hourly data for the next 48 hours too (as per the Norwegian default forecast entry) ?
I’m an ex dev so happy to do it myself if no-one else already set-up to do this ? Or some good reason I should not consider doing it. Is someone working on the new DataHub version so I should help with that ?
Thanks.
