Metering 3PN WiFi
good afternoon, I have two Metering 3PN Wifi devices, they work through the built-in YUYA integration, at first the tuya integration reflected the Power (kW) parameters.h), now the data is not reflected, only Cerrent (A) and Active Power (kW) and Voltage (V) remain, is it possible to resume Power data (kW.h)?
The device also displays other data such as Total Active Power (kW), Overall Power Factor, Frequency (Hz), is it possible to implement the output in the integration of these parameters. These settings work without a paid subscription. Otherwise, the device is used by 50%.
Please tell me, I’m new here, I’m mostly a product user, but not a developer. Perhaps you can tell me how and where to apply to expand the device’s functions. what do I need to do to resume the topic, I would like the device to work fully.
Tell me, the developer of the YUYA integration can make additions to it.
I have two such devices running, and I would like to do this for them to the fullest.
The information from this link may help.
https://www.zemismart.com/products/sdm01-tz0-12-zm
I dont know a solution, but as you got no answer I am gonna reply anyway.
For integration related issues/bugs you may want to ask the developer directly. Go the integration and select known issues. If your problem isnt already talked about, create a new issue. Then the developer can help you and you can provide logs, test the solution etc.
The Xtend Tuya integration helped me with this device. Another device for 2 channels of energy measurement does not provide entities
