I´m looking for a way to have it all regarding led strips: RGBW or single color dimming control, on/off and NORMAL wall switch.
I´m currently using several Tasmotised Sonoffs, as it provides support for a normal wall switch (through GPIO14), so the installation is invisible.
So my brainer comes when I want to add dimmer control to the led strip (adding RGBW would be astonishing), so I had thought of adding a limitless LED controller and wifi box after the sonoff, but I´m not sure about this, since i don´t know the boot up time for de controller and if it will be recognized by HA.
I have a rather large LED strip for the living room (~25 meters) fed with a 16amp power source. It turns off with a sonoff, all well. But, if I were to use a Mi Light box or a magic home, I´d have to keep the power source on all the time, and it´s not very power smart (the source always dissipates some heat when connected)
