Hello all,
I’ve successfully configured the Midea AC Lan HACS integration with a static IP, etc. I can control AC via my Home Assistant.
However, some attributes (so far I think it is just the fan_mode
) don’t update. I can succesfully change the fan speed between auto, low, med, high; but the associated attribute remains on “auto”. So by looking on Home Assistant, the fan speed always says its on auto.
Anyone else encounter something similar, or is there something I’ve missed for setting it up?
Many thanks!
P.S. changing the fan speed, while it does indeed change it on the device, HA doesn’t show the command in the logbook
