I have been maintaining the first topic, updating the contents, removing incorrect/outdated info etc…
But I agree i still have to update the parameters….
so…it will be done
[edit: Done )
so…it will be done
[edit: Done )
Is “dudanov:midea-climate-support” still the correct string to be put on esp_version that references this doc (with autoconfiguration enabled)
Because when I put that on the esp_version field, the addon doesn’t even start.
No, it isn’t. This is fully integrated in ESPHome, no need for specific versions anymore.
Where did you get that? In the first post it is already changed. Could you please point to this, so someone can change it? Thanks.
Right now you just need to setup ESPHome (standard version) and use the Midea climate component, see here in the ESPHome documentation.
Oh, it’s just that sice this link:
is mentioned on the first post, and since it has more options than the ones present on esphome (like autoconfig, the ability to disable heat mode on units that don’t utilize them or the use of the IR_TSOP on dudanov’s midea dongle), I thought that the esphome documentation was old or not related to this thread. Because I am currently using the config mentiones on esphome, but I wanted to add those extra features.
By the way, you can add this midea unit to the supported list:
Manufacturer: Midea
Model ID: MAS12C1BFH
Year: 2018
Market: MX
Done!
What you’re experiencing here, is that the link you posted is the development branch of Dudanov. He is the code owner of the ESPHome-Midea-Climate-Component. That means, what you see there, is what you get with one of the next releases from ESPHome (standard version).
Stick with the ESPHome version and just wait until these changes come up in ESPHome. If you want to be ahead, use the ESPHome-dev-branch, not Dudanovs. It would be a nightmare to support all these different versions.
Dudanov is kind enough to provide some special versions for specific problems or use cases that have come up, that would be a reason to use one these specific versions from his repository. Use these if Dudanov asks you to do so for testing purposes. Otherwise, as I said, I highly recommend to stick with the ESPHome standard or dev branches/versions.
Hallo, I,m trying to integrate a Carrier 42qhg009d8s who mounts a 16022000020169 logic board, shared by some other supported ACs, but I’m having some troubles generating the ESPhome configuration file below
esphome:
platform: ESP8266
board: d1_mini
# Enable logging
logger:
baud_rate: 0
captive_portal:
# Enable Home Assistant API
api:
ota:
password: "flying"
wifi:
ssid: "foo"
password: "bar"
ap:
ssid: "Midea-Disimpegno"
password: ""
# UART settings for Midea dongle (required)
uart:
tx_pin: 1
rx_pin: 3
baud_rate: 9600
# Optional (if you want modify settings)
midea_dongle:
strength_icon: true
# Main settings
climate:
- platform: midea_ac
name: Condizionatore Disimpegno # Use a unique name.
beeper: true # Beep on commands.
visual: # Optional. Example of visual settings override.
autoconf: true # Autoconfigure most options.
min_temperature: 16 °C # min: 16b
max_temperature: 30 °C # max: 30
temperature_step: 0.5 °C # min: 0.5
outdoor_temperature: # Optional. Create outdoor unit temperature sensor (may display incorrect values after long inactivity).
name: Temperatura Unità Esterna
power_usage: # Optional. Power usage sensor (only for devices that support this feature).
name: Consumo Condizionatore Disimpegno
humidity_setpoint: # Optional. Indoor humidity sensor (only for devices that support this feature).
name: Umidità Condizionatore Disimpegno
because
causes this error/warning
INFO Reading configuration /config/esphome/midea-disimpegno.yaml...
Failed config
climate.midea_ac: [source /config/esphome/midea-disimpegno.yaml:39]
platform: midea_ac
name: condizionatore disimpegno
beeper: True
visual:
[autoconf] is an invalid option for [climate.midea_ac]. Please check the indentation.
autoconf: True [source /config/esphome/midea-disimpegno.yaml:46]
name: Temperatura Unità esterna
power_usage:
humidity_setpoint:
name: Umidità condizionatore Disimpegno
preventing the building.
Also removing
and adding
supported_modes: # All capabilities in this section detected by autoconf.
- FAN_ONLY # This capability is always used.
- HEAT_COOL
- COOL
- HEAT
- DRY
custom_fan_modes:
- SILENT
- TURBO
supported_presets: # All capabilities in this section detected by autoconf.
- ECO
- BOOST
- SLEEP # This capability is always used.
custom_presets: # All capabilities in this section detected by autoconf.
- FREEZE_PROTECTION
supported_swing_modes:
- VERTICAL # This capability is always used.
also causates and error
Failed config
platform: midea_ac
beeper: True
visual:
[supported_modes] is an invalid option for [climate.midea_ac]. Please check the indentation.
supported_modes: [source /config/esphome/midea-disimpegno.yaml:47]
- FAN_ONLY
- HEAT_COOL
- COOL
- HEAT
- DRY
custom_fan_modes:
- SILENT
- TURBO
[supported_presets] is an invalid option for [climate.midea_ac]. Did you mean [custom_presets]?
supported_presets: [source /config/esphome/midea-disimpegno.yaml:56]
- ECO
- BOOST
- SLEEP
custom_presets:
- FREEZE_PROTECTION
[supported_swing_modes] is an invalid option for [climate.midea_ac]. Please check the indentation.
supported_swing_modes: [source /config/esphome/midea-disimpegno.yaml:62]
- VERTICAL
- HORIZONTAL
- BOTH
power_usage:
humidity_setpoint:
I’m sure that I’m drowning in an inch of water, but I hope you can forgive me and helping to get out of the puddle
I’m getting the feeling, you’re working with some kind of wrong documentation. I can’t find either of your used modes
According to the documentation, see here, you can’t use supported_modes
or autoconfig
. And for what it’s worth, just try with the basic settings and add things like modes or fan_modes after everything else is working.
Something like this and see what happens:
esphome:
platform: ESP8266
board: d1_mini
# Enable logging
logger:
baud_rate: 0
captive_portal:
api:
ota:
password: "flying"
wifi:
ssid: "foo"
password: "bar"
ap:
password: ""
uart:
tx_pin: 1
rx_pin: 3
baud_rate: 9600
midea_dongle:
strength_icon: true
# Main settings
climate:
If this works, try adding the things you need. Normally all the things that are needed are discovered automatically, so no need to add the fan_modes
. These settings are mostly, if something isn’t working out-of-the-box, but standard users as we all are won’t need these at all.
EDIT: corrected link to documentation
Your visual need to be as it is with spacing, you put autoconf in wrong place.
autoconf: true
visual:
EDIT: But I don’t see it in Docs on Midea Air Conditioner — ESPHome
sorry, I used to refer to the github documentation hoping it was correct.
I confirm that your configuration version can be builded, so do you think the AC can works without adding any other parameters?
Oh shit, i had a mistake doing the copy paste to the forum
I’m confused about your link, because I think that It takes to the HA webUI…
AC works without any other parameters. This is what I use
climate:
name: "My Midea AC"
visual:
min_temperature: 18 °C
max_temperature: 32 °C
beeper: true
swing_horizontal: true
swing_both: true
power_usage:
humidity_setpoint:
But it works without extra configs.
I take advantage of the opportunity to ask if the sensors name are for exposing to HA, so being editable, or used internally by ESPhome, so being unchangeable.
I find it difficult to understand the relative documentation section
Sorry, link to documentation was wrong, I corrected it in the post above, and here it is:
What you used is the development version of the documentation, this is only for developing purposes as there may be some things described, that won’t work in the stable version of ESPHome. What you found is the version that may be upload and reviewed to ESPHome, but it is not final, it just fits the code from the specific branch. For users the ESPHome documentation is the place to go.
And for the short code I posted, yes, that should work out-of-the-box. Mine isn’t longer and it’s working great. The point is, get it running, and afterwards see (in HA), what functions are missing.
Then check if they are supported (see documentation), and if they are, but not shown, set the parameters manually in the file.
If they are not supported, you can start a feature request by adding an issue on Github or you ask in the telegram group.
As I said, mine is working out-of-the-box without any additional settings. I just changed the behaviour in the frontend, because I’ll never ever use the “heating” from my A/C. So I disabled it. But otherwise it’s just the standard.
Let us know how it works out for you. Oh and while you’re at it, please add your model to the list of supported models, that you can find here.
. Thanks!
The names are for HA, internally ESPHome uses id
This overlapping of documentations it’s like a jungle
Thanks to have it posted, It’s a great reference
I’m starting to follow this building pathway
You disabled the heating because you live in a low latitude?
I’ll do it when I’ll could be sure that my AC can running…
So I’ll modify it…
I’m living in Germany, here normally every house has a central heating solution in place. For me, my A/C is just to cool down, if it get’s cold, I have a geothermal pump that provides us with hot water and central heating throughout the house via underfloor heating.
The A/C would be more expensive and not that flexible, the geothermal pump is environmental friendly and in the worst case I can still run it with a generator.
That’s a great marketing material! I would do this here in US,MI, but I guess it will cost me kidney and half of liver. Is your implementation “on the surface”? Meaning like meter or two under ground, or real drilled hole for tens of meters? Asking, because first is DIYable, second not co much… How is it working? How much kWh per month in January? Sorry for off-topic
hallo, I generated a new ESPhome configuration (below) following the examples given by @paddy0174 and @n1k5y , installed on a nodeMCU because previus WemosD1mini got stuck, but the AC refuses to work.
esphome:
platform: ESP8266
board: nodemcuv2
# Enable logging
logger:
baud_rate: 0
captive_portal:
api:
ota:
password: "bbc16a0461939cfcaf206e4e4187cfec"
wifi:
ssid: "Foo"
password: "Bar"
manual_ip:
static_ip: 192.168.1.76
gateway: 192.168.1.3
subnet: 255.255.255.0
ap:
password: ""
uart:
tx_pin: 1
rx_pin: 3
baud_rate: 9600
midea_dongle:
strength_icon: true
# Main settings
climate:
swing_both: true
name: "Temperatura Unità Esterna"
power_usage:
name: "Consumo Condizionatore Disimpegno"
humidity_setpoint:
name: "Umidità Condizionatore Disimpegno"
ESPhome dashboard can see online the board, HA also (as a device and entity), but nothing works.
Some screenshots from HA webUI
