After struggling for days trying to get my Midea AC working with the HACS cloud thing I thought let me just try the ESPHome module way, I was hesitant when I first looked at both options of integration and thought this way would be harder / take longer, ironically this way was actually much easier and I prefer having direct LAN access, total time spent probably 10 minutes and it is working perfectly.
I had spare nodemcu boards laying around so just used one of those and then cut a small hole in the plastic casing inside the AC with the module sticking out.
AC model: MSAG11B-12HRFN1QC2
Thanks to all of those involved…
Some images for those interested (sorry a little blurry)
EDIT: I will most likely make up a shorter cable so that the nodemcu board can be mounted inside the plastic compartment.
