I have assembled a heat pump based on 24 air conditioner units. I need it to work from an external sensor using the “follow me” function, and I have made a direct broadcast from ESP to TSOP, but it stubbornly only considers its own sensor. Additionally, this particular air conditioner does not have a button on the remote control or any mention of this function in the manual (although it does have temperature sensor holes on the remote control). Is there a way to verify whether it is not working because this function is not available?
Yaml :
Summary
esphome:
friendly_name: Тепловой насос
Midea Air Conditioner - ESPHome - Smart Home Made Simple
esp8266:
board: esp01_1m
пины 1 и 3 для Midea
logger:
baud_rate: 0 # Установка baud_rate в 0 отключает вывод логов на Serial (TX/RX)
#level: DEBUG # Можно оставить, если хотите видеть логи через веб-интерфейс
logs:
sensor: ERROR
duty_cycle: ERROR
binary_sensor: ERROR
Enable Home Assistant API
api:
encryption:
key: “JmW7u34BNdlIna/25QVc7lRT9DOmnZPa5thwvvbQyno=”
ota:
- platform: esphome
password: “123456789”
web_server:
port: 80
wifi:
ssid: !secret wifi_ssid
Enable fallback hotspot (captive portal) in case wifi connection fails
ap:
ssid: “TN Fallback Hotspot”
password: “vfhn130004”
uart: # ОБЯЗАТЕЛЬНО ДОЛЖНО БЫТЬ
tx_pin: 1 # hardware dependant
rx_pin: 3 # hardware dependant
baud_rate: 9600
remote_transmitter:
pin: GPIO12
carrier_duty_percent: 100% # 50% for IR LED, 100% for direct connect to TSOP IR receiver output.
captive_portal:
Main settings
climate:
- platform: midea
name: “teplovoy_nasos” # Use a unique name.
transmitter_id: ir_tx
period: 1s # Optional
timeout: 2s # Optional
num_attempts: 3 # Optional
autoconf: False # Autoconfigure most options.
beeper: False # Beep on commands.
visual: # Optional. Example of visual settings override.
min_temperature: 18 °C # min: 17
max_temperature: 29 °C # max: 30
temperature_step: 0.5 °C # min: 0.5
supported_modes: # All capabilities in this section detected by autoconf.- HEAT
custom_fan_modes: - SILENT
- HEAT
Удалите или закомментируйте эту секцию, если generic_thermostat будет полностью управлять:
platform: homeassistant
name: “температура управления ТН”
entity_id: sensor.zigbee_detskaya_temperature
internal: falsefilters:
- throttle: 10s
- heartbeat: 1min
- debounce: 1s
on_value: - midea_ac.follow_me: # Обратите внимание, что это должен быть список действий
temperature: !lambda “return x;”
beeper: false
log
Summary
fINFO ESPHome 2025.9.0
INFO Reading configuration /config/esphome/teplovoy-nnasos.yaml…
WARNING ‘teplovoy_nasos’: Using the ‘_’ (underscore) character in the hostname is discouraged as it can cause problems with some DHCP and local name services. For more information, see Frequently Asked Questions - ESPHome - Smart Home Made Simple
INFO Starting log output from 192.168.1.54 using esphome API
INFO Successfully resolved teplovoy_nasos @ 192.168.1.54 in 0.000s
INFO Successfully connected to teplovoy_nasos @ 192.168.1.54 in 0.037s
INFO Successful handshake with teplovoy_nasos @ 192.168.1.54 in 2.603s
[23:30:39.219][I][app:185]: ESPHome version 2025.9.0 compiled on Oct 8 2025, 22:32:33
[23:30:39.219][C][wifi:661]: WiFi:
[23:30:39.219][C][wifi:444]: Local MAC: 68:C6:3A:B6:BB:0D
[23:30:39.219][C][wifi:449]: SSID: ‘ID’[redacted]
[23:30:39.219][C][wifi:452]: IP Address: 192.168.1.54
[23:30:39.219][C][wifi:456]: BSSID: 50:FF:20:8D:64:EC[redacted]
[23:30:39.219][C][wifi:456]: Hostname: ‘teplovoy_nasos’
[23:30:39.219][C][wifi:456]: Signal strength: -47 dB ▂▄▆█
[23:30:39.219][C][wifi:467]: Channel: 6
[23:30:39.219][C][wifi:467]: Subnet: 255.255.255.0
[23:30:39.219][C][wifi:467]: Gateway: 192.168.1.1
[23:30:39.219][C][wifi:467]: DNS1: 192.168.1.1
[23:30:39.219][C][wifi:467]: DNS2: 0.0.0.0
[23:30:39.219][C][logger:273]: Logger:
[23:30:39.219][C][logger:273]: Max Level: DEBUG
[23:30:39.219][C][logger:273]: Initial Level: DEBUG
[23:30:39.220][C][logger:279]: Log Baud Rate: 0
[23:30:39.220][C][logger:279]: Hardware UART: UART0
[23:30:39.220][C][logger:291]: Level for ‘binary_sensor’: ERROR
[23:30:39.220][C][logger:291]: Level for ‘duty_cycle’: ERROR
[23:30:39.220][C][logger:291]: Level for ‘sensor’: ERROR
[23:30:39.220][C][uart.arduino_esp8266:117]: UART Bus:
[23:30:39.220][C][uart.arduino_esp8266:118]: TX Pin: GPIO1
[23:30:39.220][C][uart.arduino_esp8266:119]: RX Pin: GPIO3
[23:30:39.221][C][uart.arduino_esp8266:121]: RX Buffer Size: 256
[23:30:39.221][C][uart.arduino_esp8266:123]: Baud Rate: 9600 baud
[23:30:39.221][C][uart.arduino_esp8266:123]: Data Bits: 8
[23:30:39.221][C][uart.arduino_esp8266:123]: Parity: NONE
[23:30:39.221][C][uart.arduino_esp8266:123]: Stop bits: 1
[23:30:39.221][C][uart.arduino_esp8266:130]: Using hardware serial interface.
[23:30:39.256][C][remote_transmitter:018]: Remote Transmitter:
[23:30:39.256][C][remote_transmitter:018]: Carrier Duty: 100%
[23:30:39.259][C][remote_transmitter:022]: Pin: GPIO12
[23:30:39.279][C][web_server:309]: Web Server:
[23:30:39.279][C][web_server:309]: Address: teplovoy_nasos.local:80
[23:30:39.293][C][midea:106]: MideaDongle:
[23:30:39.293][C][midea:106]: Period: 1000ms
[23:30:39.293][C][midea:106]: Response timeout: 2000ms
[23:30:39.293][C][midea:106]: Request attempts: 3
[23:30:39.294][C][midea:113]: Using RemoteTransmitter
[23:30:39.294][C][midea:571]: ClimateTraits:
[23:30:39.294][C][midea:572]: Visual settings:
[23:30:39.294][C][midea:572]: - Min temperature: 18.0
[23:30:39.294][C][midea:572]: - Max temperature: 29.0
[23:30:39.294][C][midea:572]: - Temperature step:
[23:30:39.294][C][midea:572]: Target: 0.5
[23:30:39.294][C][midea:581]: Current: 0.5
[23:30:39.294][C][midea:593]: Supports current temperature
[23:30:39.294][C][midea:605]: Supported modes:
[23:30:39.294][C][midea:607]: - OFF
[23:30:39.294][C][midea:607]: - HEAT
[23:30:39.294][C][midea:610]: Supported fan modes:
[23:30:39.294][C][midea:612]: - AUTO
[23:30:39.294][C][midea:612]: - LOW
[23:30:39.294][C][midea:612]: - MEDIUM
[23:30:39.294][C][midea:612]: - HIGH
[23:30:39.294][C][midea:615]: Supported custom fan modes:
[23:30:39.294][C][midea:617]: - silent
[23:30:39.298][C][esphome.ota:075]: Over-The-Air updates:
[23:30:39.298][C][esphome.ota:075]: Address: teplovoy_nasos.local:8266
[23:30:39.298][C][esphome.ota:075]: Version: 2
[23:30:39.298][C][esphome.ota:082]: Password configured
[23:30:39.312][C][safe_mode:018]: Safe Mode:
[23:30:39.312][C][safe_mode:018]: Successful after: 60s
[23:30:39.312][C][safe_mode:018]: Invoke after: 10 attempts
[23:30:39.312][C][safe_mode:018]: Duration: 300s
[23:30:39.319][C][api:205]: Server:
[23:30:39.319][C][api:205]: Address: teplovoy_nasos.local:6053
[23:30:39.321][C][api:210]: Noise encryption: YES
[23:30:39.330][C][mdns:213]: mDNS:
[23:30:39.330][C][mdns:213]: Hostname: teplovoy_nasos
[23:30:39.340][C][homeassistant.sensor:015]: Homeassistant Sensor ‘температура управления ТН’
[23:30:39.340][C][homeassistant.sensor:015]: State Class: ‘’
[23:30:39.340][C][homeassistant.sensor:015]: Unit of Measurement: ‘’
[23:30:39.340][C][homeassistant.sensor:015]: Accuracy Decimals: 1
[23:30:39.342][C][homeassistant.sensor:031]: Entity ID: ‘sensor.zigbee_detskaya_temperature’
[23:30:39.575][D][ApplianceBase:063]: RX: AA 22 AC 00 00 00 00 00 03 03 C0 01 82 66 7F 7F 00 00 00 00 00 60 FF 00 00 00 00 00 00 00 00 06 36 52 98
[23:30:39.578][D][AirConditioner:204]: New status data received. Parsing…
[23:30:39.578][D][ApplianceBase:154]: Destroying the request…
[23:30:40.043][D][AirConditioner:177]: Enqueuing a GET_STATUS(0x41) request…
[23:30:40.049][D][ApplianceBase:173]: Enqueuing the request…
[23:30:40.049][D][ApplianceBase:075]: Getting and sending a request from the queue…
[23:30:40.049][D][ApplianceBase:162]: TX: AA 21 AC 8D 00 00 00 00 03 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 1A D4 EA
[23:30:40.588][D][ApplianceBase:063]: RX: AA 22 AC 00 00 00 00 00 03 03 C0 01 82 66 7F 7F 00 00 00 00 00 60 FF 00 00 00 00 00 00 00 00 06 D4 07 45
[23:30:40.591][D][AirConditioner:204]: New status data received. Parsing…
[23:30:40.592][D][ApplianceBase:154]: Destroying the request…
[23:30:41.050][D][AirConditioner:177]: Enqueuing a GET_STATUS(0x41) request…
[23:30:41.054][D][ApplianceBase:173]: Enqueuing the request…
[23:30:41.054][D][ApplianceBase:075]: Getting and sending a request from the queue…
[23:30:41.054][D][ApplianceBase:162]: TX: AA 21 AC 8D 00 00 00 00 03 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 1B 8A 33
[23:30:41.614][D][ApplianceBase:063]: RX: AA 22 AC 00 00 00 00 00 03 03 C0 01 82 66 7F 7F 00 00 00 00 00 60 FF 00 00 00 00 00 00 00 00 06 8A C3 D3
[23:30:41.617][D][AirConditioner:204]: New status data received. Parsing…
[23:30:41.617][D][ApplianceBase:154]: Destroying the request…
[23:30:42.062][D][AirConditioner:177]: Enqueuing a GET_STATUS(0x41) request…
[23:30:42.064][D][ApplianceBase:173]: Enqueuing the request…
[23:30:42.064][D][ApplianceBase:075]: Getting and sending a request from the queue…
[23:30:42.064][D][ApplianceBase:162]: TX: AA 21 AC 8D 00 00 00 00 03 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 1C 09 B3
[23:30:42.608][D][ApplianceBase:063]: RX: AA 22 AC 00 00 00 00 00 03 03 C0 01 82 66 7F 7F 00 00 00 00 00 60 FF 00 00 00 00 00 00 00 00 06 09 AD 6A
[23:30:42.610][D][AirConditioner:204]: New status data received. Parsing…
[23:30:42.611][D][ApplianceBase:154]: Destroying the request…
[23:30:43.075][D][AirConditioner:177]: Enqueuing a GET_STATUS(0x41) request…
[23:30:43.078][D][ApplianceBase:173]: Enqueuing the request…
[23:30:43.078][D][ApplianceBase:075]: Getting and sending a request from the queue…
[23:30:43.078][D][ApplianceBase:162]: TX: AA 21 AC 8D 00 00 00 00 03 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 1D 57 64
[23:30:43.623][D][ApplianceBase:063]: RX: AA 22 AC 00 00 00 00 00 03 03 C0 01 82 66 7F 7F 00 00 00 00 00 60 FF 00 00 00 00 00 00 00 00 06 57 69 60
[23:30:43.625][D][AirConditioner:204]: New status data received. Parsing…
[23:30:43.625][D][ApplianceBase:154]: Destroying the request…
[23:30:44.087][D][AirConditioner:177]: Enqueuing a GET_STATUS(0x41) request…
[23:30:44.092][D][ApplianceBase:173]: Enqueuing the request…
[23:30:44.092][D][ApplianceBase:075]: Getting and sending a request from the queue…
[23:30:44.092][D][ApplianceBase:162]: TX: AA 21 AC 8D 00 00 00 00 03 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 1E B5 05
[23:30:44.636][D][ApplianceBase:063]: RX: AA 22 AC 00 00 00 00 00 03 03 C0 01 82 66 7F 7F 00 00 00 00 00 60 FF 00 00 00 00 00 00 00 00 06 B5 3C 2F
[23:30:44.638][D][AirConditioner:204]: New status data received. Parsing…
[23:30:44.638][D][ApplianceBase:154]: Destroying the request…
[23:30:45.095][D][AirConditioner:177]: Enqueuing a GET_STATUS(0x41) request…
[23:30:45.097][D][ApplianceBase:173]: Enqueuing the request…
[23:30:45.107][D][ApplianceBase:075]: Getting and sending a request from the queue…
[23:30:45.109][D][ApplianceBase:162]: TX: AA 21 AC 8D 00 00 00 00 03 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 1F EB CE
[23:30:45.660][D][ApplianceBase:063]: RX: AA 22 AC 00 00 00 00 00 03 03 C0 01 82 66 7F 7F 00 00 00 00 00 60 FF 00 00 00 00 00 00 00 00 06 EB F8 3D
[23:30:45.662][D][AirConditioner:204]: New status data received. Parsing…
[23:30:45.662][D][ApplianceBase:154]: Destroying the request…
[23:30:46.113][D][AirConditioner:177]: Enqueuing a GET_STATUS(0x41) request…
[23:30:46.116][D][ApplianceBase:173]: Enqueuing the request…
[23:30:46.116][D][ApplianceBase:075]: Getting and sending a request from the queue…
[23:30:46.116][D][ApplianceBase:162]: TX: AA 21 AC 8D 00 00 00 00 03 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 20 14 A4
[23:30:46.662][D][ApplianceBase:063]: RX: AA 22 AC 00 00 00 00 00 03 03 C0 01 82 66 7F 7F 00 00 00 00 00 60 FF 00 00 00 00 00 00 00 00 06 14 CD 3F
[23:30:46.665][D][AirConditioner:204]: New status data received. Parsing…
[23:30:46.665][D][ApplianceBase:154]: Destroying the request…
[23:30:47.128][D][AirConditioner:177]: Enqueuing a GET_STATUS(0x41) request…
[23:30:47.138][D][ApplianceBase:173]: Enqueuing the request…
[23:30:47.138][D][ApplianceBase:075]: Getting and sending a request from the queue…
[23:30:47.138][D][ApplianceBase:162]: TX: AA 21 AC 8D 00 00 00 00 03 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 21 4A 6D
[23:30:47.677][D][ApplianceBase:063]: RX: AA 22 AC 00 00 00 00 00 03 03 C0 01 82 66 7F 7F 00 00 00 00 00 60 FF 00 00 00 00 00 00 00 00 06 4A 09 CD
[23:30:47.679][D][AirConditioner:204]: New status data received. Parsing…
[23:30:47.679][D][ApplianceBase:154]: Destroying the request…
[23:30:48.139][D][AirConditioner:177]: Enqueuing a GET_STATUS(0x41) request…
[23:30:48.143][D][ApplianceBase:173]: Enqueuing the request…
[23:30:48.144][D][ApplianceBase:075]: Getting and sending a request from the queue…
[23:30:48.144][D][ApplianceBase:162]: TX: AA 21 AC 8D 00 00 00 00 03 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 22 A8 0E
[23:30:49.497][D][ApplianceBase:063]: RX: AA 22 AC 00 00 00 00 00 03 03 C0 01 82 66 7F 7F 00 00 00 00 00 60 FF 00 00 00 00 00 00 00 00 06 A8 5C 1C
[23:30:49.540][D][AirConditioner:204]: New status data received. Parsing…
[23:30:49.540][D][ApplianceBase:154]: Destroying the request…
[23:30:49.540][D][AirConditioner:177]: Enqueuing a GET_STATUS(0x41) request…
[23:30:49.540][D][ApplianceBase:173]: Enqueuing the request…
[23:30:49.540][D][ApplianceBase:075]: Getting and sending a request from the queue…
[23:30:49.540][D][ApplianceBase:162]: TX: AA 21 AC 8D 00 00 00 00 03 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 23 F6 BF
[23:30:49.954][D][ApplianceBase:063]: RX: AA 22 AC 00 00 00 00 00 03 03 C0 01 82 66 7F 7F 00 00 00 00 00 60 FF 00 00 00 00 00 00 00 00 06 F6 98 92
[23:30:49.957][D][AirConditioner:204]: New status data received. Parsing…
[23:30:49.957][D][ApplianceBase:154]: Destroying the request…
[23:30:50.502][D][AirConditioner:177]: Enqueuing a GET_STATUS(0x41) request…
[23:30:50.515][D][ApplianceBase:173]: Enqueuing the request…
[23:30:50.515][D][ApplianceBase:075]: Getting and sending a request from the queue…
[23:30:50.515][D][ApplianceBase:162]: TX: AA 21 AC 8D 00 00 00 00 03 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 24 75 3F
[23:30:51.065][D][ApplianceBase:063]: RX: AA 22 AC 00 00 00 00 00 03 03 C0 01 82 66 7F 7F 00 00 00 00 00 60 FF 00 00 00 00 00 00 00 00 06 75 F6 B5
[23:30:51.068][D][AirConditioner:204]: New status data received. Parsing…
[23:30:51.068][D][ApplianceBase:154]: Destroying the request…
[23:30:51.511][D][AirConditioner:177]: Enqueuing a GET_STATUS(0x41) request…
[23:30:51.516][D][ApplianceBase:173]: Enqueuing the request…
[23:30:51.517][D][ApplianceBase:075]: Getting and sending a request from the queue…
[23:30:51.517][D][ApplianceBase:162]: TX: AA 21 AC 8D 00 00 00 00 03 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 25 2B 88
[23:30:52.059][D][ApplianceBase:063]: RX: AA 22 AC 00 00 00 00 00 03 03 C0 01 82 66 7F 7F 00 00 00 00 00 60 FF 00 00 00 00 00 00 00 00 06 2B 32 C3
[23:30:52.061][D][AirConditioner:204]: New status data received. Parsing…
[23:30:52.062][D][ApplianceBase:154]: Destroying the request…
[23:30:52.520][D][AirConditioner:177]: Enqueuing a GET_STATUS(0x41) request…
[23:30:52.526][D][ApplianceBase:173]: Enqueuing the request…
[23:30:52.529][D][ApplianceBase:075]: Getting and sending a request from the queue…
[23:30:52.529][D][ApplianceBase:162]: TX: AA 21 AC 8D 00 00 00 00 03 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 26 C9 E9
[23:30:53.894][D][ApplianceBase:063]: RX: AA 22 AC 00 00 00 00 00 03 03 C0 01 82 66 7F 7F 00 00 00 00 00 60 FF 00 00 00 00 00 00 00 00 06 C9 67 F0
[23:30:53.896][D][AirConditioner:204]: New status data received. Parsing…
[23:30:53.896][D][ApplianceBase:154]: Destroying the request…
[23:30:53.897][D][AirConditioner:177]: Enqueuing a GET_STATUS(0x41) request…
[23:30:53.897][D][ApplianceBase:173]: Enqueuing the request…
[23:30:53.897][D][ApplianceBase:075]: Getting and sending a request from the queue…
[23:30:53.897][D][ApplianceBase:162]: TX: AA 21 AC 8D 00 00 00 00 03 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 27 97 1A
[23:30:54.439][D][ApplianceBase:063]: RX: AA 22 AC 00 00 00 00 00 03 03 C0 01 82 66 7F 7F 00 00 00 00 00 60 FF 00 00 00 00 00 00 00 00 06 97 A3 E6
[23:30:54.442][D][AirConditioner:204]: New status data received. Parsing…
[23:30:54.442][D][ApplianceBase:154]: Destroying the request…
[23:30:54.903][D][AirConditioner:177]: Enqueuing a GET_STATUS(0x41) request…
[23:30:54.907][D][ApplianceBase:173]: Enqueuing the request…
[23:30:54.908][D][ApplianceBase:075]: Getting and sending a request from the queue…
[23:30:54.908][D][ApplianceBase:162]: TX: AA 21 AC 8D 00 00 00 00 03 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 28 D6 DA
[23:30:56.912][D][ApplianceBase:139]: Response timeout…
[23:30:56.915][D][ApplianceBase:146]: Sending request again. Attempts left: 2…
[23:30:56.916][D][ApplianceBase:162]: TX: AA 21 AC 8D 00 00 00 00 03 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 28 D6 DA
[23:30:57.051][D][ApplianceBase:063]: RX: AA 22 AC 00 00 00 00 00 03 03 C0 01 82 66 7F 7F 00 00 00 00 00 60 FF 00 00 00 00 00 00 00 00 06 D6 BB 8F
[23:30:57.054][D][AirConditioner:204]: New status data received. Parsing…
[23:30:57.054][D][ApplianceBase:154]: Destroying the request…
[23:30:57.855][D][ApplianceBase:129]: Enqueuing a DEVICE_NETWORK(0x0D) notification…
[23:30:57.857][D][ApplianceBase:173]: Enqueuing the request…
[23:30:57.926][D][ApplianceBase:075]: Getting and sending a request from the queue…
[23:30:57.929][D][ApplianceBase:162]: TX: AA 1F AC B3 00 00 00 00 03 0D 01 01 04 36 01 A8 C0 FF 00 00 00 00 00 00 00 00 00 00 00 00 C7 07
[23:30:57.929][D][ApplianceBase:154]: Destroying the request…
[23:30:58.338][D][AirConditioner:131]: Enqueuing a GET_POWERUSAGE(0x41) request…
[23:30:58.341][D][ApplianceBase:173]: Enqueuing the request…
[23:30:58.438][D][ApplianceBase:063]: RX: AA 1F AC 00 00 00 00 00 03 0D 01 01 04 36 01 A8 C0 FF 00 00 00 00 00 00 00 00 00 00 00 00 C7 BA
[23:30:58.937][D][ApplianceBase:075]: Getting and sending a request from the queue…
[23:30:58.939][D][ApplianceBase:162]: TX: AA 22 AC 8E 00 00 00 00 03 03 41 21 01 44 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 29 A8 22
[23:30:59.466][D][ApplianceBase:063]: RX: AA 1F AC 00 00 00 00 00 03 03 C1 21 01 44 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 35 D3
[23:30:59.470][D][ApplianceBase:154]: Destroying the request…
[23:30:59.946][D][AirConditioner:177]: Enqueuing a GET_STATUS(0x41) request…
[23:30:59.951][D][ApplianceBase:173]: Enqueuing the request…
[23:30:59.951][D][ApplianceBase:075]: Getting and sending a request from the queue…
[23:30:59.951][D][ApplianceBase:162]: TX: AA 21 AC 8D 00 00 00 00 03 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 2A 6A 44
[23:31:00.490][D][ApplianceBase:063]: RX: AA 22 AC 00 00 00 00 00 03 03 C0 01 82 66 7F 7F 00 00 00 00 00 60 FF 00 00 00 00 00 00 00 00 06 6A 2A 8C
[23:31:00.493][D][AirConditioner:204]: New status data received. Parsing…
[23:31:00.493][D][ApplianceBase:154]: Destroying the request…
[23:31:00.950][D][AirConditioner:177]: Enqueuing a GET_STATUS(0x41) request…
[23:31:00.960][D][ApplianceBase:173]: Enqueuing the request…
[23:31:00.960][D][ApplianceBase:075]: Getting and sending a request from the queue…
[23:31:00.960][D][ApplianceBase:162]: TX: AA 21 AC 8D 00 00 00 00 03 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 2B 34 79
[23:31:01.505][D][ApplianceBase:063]: RX: AA 22 AC 00 00 00 00 00 03 03 C0 01 82 66 7F 7F 00 00 00 00 00 60 FF 00 00 00 00 00 00 00 00 06 34 EE FE
[23:31:01.533][D][AirConditioner:204]: New status data received. Parsing…
[23:31:01.533][D][ApplianceBase:154]: Destroying the request…
[23:31:01.966][D][AirConditioner:177]: Enqueuing a GET_STATUS(0x41) request…
[23:31:01.971][D][ApplianceBase:173]: Enqueuing the request…
[23:31:01.971][D][ApplianceBase:075]: Getting and sending a request from the queue…
[23:31:01.971][D][ApplianceBase:162]: TX: AA 21 AC 8D 00 00 00 00 03 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 2C B7 F5
[23:31:02.514][D][ApplianceBase:063]: RX: AA 22 AC 00 00 00 00 00 03 03 C0 01 82 66 7F 7F 00 00 00 00 00 60 FF 00 00 00 00 00 00 00 00 06 B7 80 E9
[23:31:02.516][D][AirConditioner:204]: New status data received. Parsing…
[23:31:02.517][D][ApplianceBase:154]: Destroying the request…
[23:31:02.978][D][AirConditioner:177]: Enqueuing a GET_STATUS(0x41) request…
[23:31:02.982][D][ApplianceBase:173]: Enqueuing the request…
[23:31:02.983][D][ApplianceBase:075]: Getting and sending a request from the queue…
[23:31:02.983][D][ApplianceBase:162]: TX: AA 21 AC 8D 00 00 00 00 03 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 2D E9 C2
[23:31:03.540][D][ApplianceBase:063]: RX: AA 22 AC 00 00 00 00 00 03 03 C0 01 82 66 7F 7F 00 00 00 00 00 60 FF 00 00 00 00 00 00 00 00 06 E9 44 F3
[23:31:03.542][D][AirConditioner:204]: New status data received. Parsing…
[23:31:03.542][D][ApplianceBase:154]: Destroying the request…
[23:31:03.987][D][AirConditioner:177]: Enqueuing a GET_STATUS(0x41) request…
[23:31:03.989][D][ApplianceBase:173]: Enqueuing the request…
[23:31:03.998][D][ApplianceBase:075]: Getting and sending a request from the queue…
[23:31:04.000][D][ApplianceBase:162]: TX: AA 21 AC 8D 00 00 00 00 03 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 2E 0B 9F
[23:31:04.547][D][ApplianceBase:063]: RX: AA 22 AC 00 00 00 00 00 03 03 C0 01 82 66 7F 7F 00 00 00 00 00 60 FF 00 00 00 00 00 00 00 00 06 0B 11 04
[23:31:04.552][D][AirConditioner:204]: New status data received. Parsing…
[23:31:04.552][D][ApplianceBase:154]: Destroying the request…
[23:31:05.013][D][AirConditioner:177]: Enqueuing a GET_STATUS(0x41) request…
[23:31:05.015][D][ApplianceBase:173]: Enqueuing the request…
[23:31:05.015][D][ApplianceBase:075]: Getting and sending a request from the queue…
[23:31:05.015][D][ApplianceBase:162]: TX: AA 21 AC 8D 00 00 00 00 03 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 2F 55 54
[23:31:06.613][D][ApplianceBase:063]: RX: AA 22 AC 00 00 00 00 00 03 03 C0 01 82 66 7F 7F 00 00 00 00 00 60 FF 00 00 00 00 00 00 00 00 06 55 D5 F6
[23:31:06.617][D][AirConditioner:204]: New status data received. Parsing…
[23:31:06.617][D][ApplianceBase:154]: Destroying the request…
[23:31:06.617][D][AirConditioner:177]: Enqueuing a GET_STATUS(0x41) request…
[23:31:06.617][D][ApplianceBase:173]: Enqueuing the request…
[23:31:06.618][D][ApplianceBase:075]: Getting and sending a request from the queue…
[23:31:06.618][D][ApplianceBase:162]: TX: AA 21 AC 8D 00 00 00 00 03 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 30 89 1F
[23:31:07.086][D][ApplianceBase:063]: RX: AA 22 AC 00 00 00 00 00 03 03 C0 01 82 66 7F 7F 00 00 00 00 00 60 FF 00 00 00 00 00 00 00 00 06 89 21 76
[23:31:07.089][D][AirConditioner:204]: New status data received. Parsing…
[23:31:07.089][D][ApplianceBase:154]: Destroying the request…
[23:31:07.624][D][AirConditioner:177]: Enqueuing a GET_STATUS(0x41) request…
[23:31:07.627][D][ApplianceBase:173]: Enqueuing the request…
[23:31:07.627][D][ApplianceBase:075]: Getting and sending a request from the queue…
[23:31:07.627][D][ApplianceBase:162]: TX: AA 21 AC 8D 00 00 00 00 03 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 31 D7 D0
[23:31:08.170][D][ApplianceBase:063]: RX: AA 22 AC 00 00 00 00 00 03 03 C0 01 82 66 7F 7F 00 00 00 00 00 60 FF 00 00 00 00 00 00 00 00 06 D7 E5 64
[23:31:08.173][D][AirConditioner:204]: New status data received. Parsing…
[23:31:08.173][D][ApplianceBase:154]: Destroying the request…
[23:31:08.631][D][AirConditioner:177]: Enqueuing a GET_STATUS(0x41) request…
[23:31:08.640][D][ApplianceBase:173]: Enqueuing the request…
[23:31:08.640][D][ApplianceBase:075]: Getting and sending a request from the queue…
[23:31:08.640][D][ApplianceBase:162]: TX: AA 21 AC 8D 00 00 00 00 03 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 32 35 71
[23:31:09.184][D][ApplianceBase:063]: RX: AA 22 AC 00 00 00 00 00 03 03 C0 01 82 66 7F 7F 00 00 00 00 00 60 FF 00 00 00 00 00 00 00 00 06 35 B0 3B
[23:31:09.187][D][AirConditioner:204]: New status data received. Parsing…
[23:31:09.187][D][ApplianceBase:154]: Destroying the request…
[23:31:09.648][D][AirConditioner:177]: Enqueuing a GET_STATUS(0x41) request…
[23:31:09.653][D][ApplianceBase:173]: Enqueuing the request…
[23:31:09.653][D][ApplianceBase:075]: Getting and sending a request from the queue…
[23:31:09.654][D][ApplianceBase:162]: TX: AA 21 AC 8D 00 00 00 00 03 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 33 6B 3A
[23:31:10.198][D][ApplianceBase:063]: RX: AA 22 AC 00 00 00 00 00 03 03 C0 01 82 66 7F 7F 00 00 00 00 00 60 FF 00 00 00 00 00 00 00 00 06 6B 74 41
[23:31:10.201][D][AirConditioner:204]: New status data received. Parsing…
[23:31:10.201][D][ApplianceBase:154]: Destroying the request…
[23:31:10.654][D][AirConditioner:177]: Enqueuing a GET_STATUS(0x41) request…
[23:31:10.657][D][ApplianceBase:173]: Enqueuing the request…
[23:31:10.665][D][ApplianceBase:075]: Getting and sending a request from the queue…
[23:31:10.665][D][ApplianceBase:162]: TX: AA 21 AC 8D 00 00 00 00 03 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 34 E8 BC
[23:31:11.210][D][ApplianceBase:063]: RX: AA 22 AC 00 00 00 00 00 03 03 C0 01 82 66 7F 7F 00 00 00 00 00 60 FF 00 00 00 00 00 00 00 00 06 E8 1A 1E
[23:31:11.213][D][AirConditioner:204]: New status data received. Parsing…
[23:31:11.213][D][ApplianceBase:154]: Destroying the request…
[23:31:11.678][D][AirConditioner:177]: Enqueuing a GET_STATUS(0x41) request…
[23:31:11.681][D][ApplianceBase:173]: Enqueuing the request…
[23:31:11.681][D][ApplianceBase:075]: Getting and sending a request from the queue…
[23:31:11.681][D][ApplianceBase:162]: TX: AA 21 AC 8D 00 00 00 00 03 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 35 B6 ED
[23:31:12.228][D][ApplianceBase:063]: RX: AA 22 AC 00 00 00 00 00 03 03 C0 01 82 66 7F 7F 00 00 00 00 00 60 FF 00 00 00 00 00 00 00 00 06 B6 DE 8C
[23:31:12.230][D][AirConditioner:204]: New status data received. Parsing…
[23:31:12.230][D][ApplianceBase:154]: Destroying the request…
[23:31:12.688][D][AirConditioner:177]: Enqueuing a GET_STATUS(0x41) request…
[23:31:12.691][D][ApplianceBase:173]: Enqueuing the request…
[23:31:12.691][D][ApplianceBase:075]: Getting and sending a request from the queue…
[23:31:12.691][D][ApplianceBase:162]: TX: AA 21 AC 8D 00 00 00 00 03 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 36 54 4E
[23:31:13.235][D][ApplianceBase:063]: RX: AA 22 AC 00 00 00 00 00 03 03 C0 01 82 66 7F 7F 00 00 00 00 00 60 FF 00 00 00 00 00 00 00 00 06 54 8B 41
[23:31:13.237][D][AirConditioner:204]: New status data received. Parsing…
[23:31:13.237][D][ApplianceBase:154]: Destroying the request…
[23:31:13.701][D][AirConditioner:177]: Enqueuing a GET_STATUS(0x41) request…
[23:31:13.704][D][ApplianceBase:173]: Enqueuing the request…
[23:31:13.704][D][ApplianceBase:075]: Getting and sending a request from the queue…
[23:31:13.704][D][ApplianceBase:162]: TX: AA 21 AC 8D 00 00 00 00 03 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 37 0A 97
[23:31:14.242][D][ApplianceBase:063]: RX: AA 22 AC 00 00 00 00 00 03 03 C0 01 82 66 7F 7F 00 00 00 00 00 60 FF 00 00 00 00 00 00 00 00 06 0A 4F C7
[23:31:14.245][D][AirConditioner:204]: New status data received. Parsing…
[23:31:14.245][D][ApplianceBase:154]: Destroying the request…
[23:31:14.706][D][AirConditioner:177]: Enqueuing a GET_STATUS(0x41) request…
[23:31:14.710][D][ApplianceBase:173]: Enqueuing the request…
[23:31:14.710][D][ApplianceBase:075]: Getting and sending a request from the queue…
[23:31:14.710][D][ApplianceBase:162]: TX: AA 21 AC 8D 00 00 00 00 03 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 38 4B 55
[23:31:15.783][D][ApplianceBase:063]: RX: AA 22 AC 00 00 00 00 00 03 03 C0 01 82 66 7F 7F 00 00 00 00 00 60 FF 00 00 00 00 00 00 00 00 06 4B 57 7E
[23:31:15.787][D][AirConditioner:204]: New status data received. Parsing…
[23:31:15.788][D][ApplianceBase:154]: Destroying the request…
[23:31:15.788][D][AirConditioner:177]: Enqueuing a GET_STATUS(0x41) request…
[23:31:15.788][D][ApplianceBase:173]: Enqueuing the request…
[23:31:15.788][D][ApplianceBase:075]: Getting and sending a request from the queue…
[23:31:15.788][D][ApplianceBase:162]: TX: AA 21 AC 8D 00 00 00 00 03 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 39 15 8A
[23:31:16.249][D][ApplianceBase:063]: RX: AA 22 AC 00 00 00 00 00 03 03 C0 01 82 66 7F 7F 00 00 00 00 00 60 FF 00 00 00 00 00 00 00 00 06 15 93 78
[23:31:16.251][D][AirConditioner:204]: New status data received. Parsing…
[23:31:16.251][D][ApplianceBase:154]: Destroying the request…
[23:31:16.792][D][AirConditioner:177]: Enqueuing a GET_STATUS(0x41) request…
[23:31:16.800][D][ApplianceBase:173]: Enqueuing the request…
[23:31:16.800][D][ApplianceBase:075]: Getting and sending a request from the queue…
[23:31:16.800][D][ApplianceBase:162]: TX: AA 21 AC 8D 00 00 00 00 03 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 3A F7 A7
[23:31:17.315][D][ApplianceBase:063]: RX: AA 22 AC 00 00 00 00 00 03 03 C0 01 82 66 7F 7F 00 00 00 00 00 60 FF 00 00 00 00 00 00 00 00 06 15 93 78
[23:31:17.327][D][AirConditioner:204]: New status data received. Parsing…
[23:31:17.327][D][ApplianceBase:154]: Destroying the request…
[23:31:17.807][D][AirConditioner:177]: Enqueuing a GET_STATUS(0x41) request…
[23:31:17.813][D][ApplianceBase:173]: Enqueuing the request…
[23:31:17.816][D][ApplianceBase:075]: Getting and sending a request from the queue…
[23:31:17.816][D][ApplianceBase:162]: TX: AA 21 AC 8D 00 00 00 00 03 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 3B A9 F4
[23:31:18.480][D][midea:140]: Follow me action called with temperature: 21.84000 °C, rounded to: 22 °C
[23:31:18.597][D][remote_transmitter:079]: Sending remote code
[23:31:19.823][D][ApplianceBase:139]: Response timeout…
[23:31:19.826][D][ApplianceBase:146]: Sending request again. Attempts left: 2…
[23:31:19.826][D][ApplianceBase:162]: TX: AA 21 AC 8D 00 00 00 00 03 03 41 81 00
