Miele Integration disappeared and now not installable [solved]
I had the Miele integration working. For some inexplicable reason, it’s no longer working, has disappeared from the integration list, and of course, I can no longer display my Miele appliances.
So far, so bad. It gets worse: I can no longer install the integration. The message reads: “This integration only allows one configuration - Miele only supports one configuration. Adding more is not necessary.”
I have no OAuth entries for Miele.
I have no Miele entry in custom_components.
I have no Miele installed in HACS.
I’m at a lost! Can anybody support me in fixing the issue - get Miele back into operation?
Have you checked that it’s not disabled? In the integrations page there is a button you can press to show disabled integrations.
Oh! @fleskefjes How stupid one can be. It was there being ignired. However that may have happened (user in frint of PC I assume).
Trying to install works now a step ahead, but ends up with a message: " Oops… an error occured - Unexpected response Service Temporarily Unavailable"
it seems to end up at nabucasa
https://account-link.nabucasa.com/authorize_callback?code=DE_xxxxxxxx
Maybe I am going to check tomorrow again…
it helped me to remove enabled apps in the Miele app: Go to Profile > Profile settings > Partner Apps, delete any Home Assistant entry.
now an installatiion of the Miele integration works
This forum is English only.
