I try to add my Washing-Maschine to HA, but it fails during Setup:
I Added it in the Mobile-App → Everything is ok
I add a new device in HA (using the build-in Miele-Integration), which leads me to: https://api.mcs3.miele.com/thirdparty/login?client_id=…
where I enter my Credentials from the Mobile App.
Next I get a Window from the Miele-Page asking me to grad HomeAssistant Access to my Devices. I accept that and get to a Site called: Nabu Casa Account Link…
Where the Error-Message
Oops... an error occured
Unexpected response Service Temporarily Unavailable
comes up. Yes, it says “temporarly” but it is there the whole Weekend so far.
Wow, that’s crazy!! That worked for me too. Thank you very much!!
BTW: I had to click back twice! First back=give access to the App, second back-click=Credentials-Window. You have to go back to that Windows (as Info for other People with the same Problem)
I am still encountering the same error despite several attempts to install the Miele app and integration. When I log in with a different country, the message “Account connection failed” appears, which shows that the login generally works. However, as soon as I select my actual country, I receive the error message “Oops… an error occurred…”. Repeated attempts unfortunately do not change this. No messages appear in the log.
Same problem for me, going back and pressing allow still comes up with the same error “Oops… an error occured” anyone had any luck with this or any ideas what to try?
Same problem as OP here, none of the suggestions here worked for me. Had a message regarding Nabu Casa not knowing my adress because they didn’t here about my HA for too long (sth about more than 15 mins), but that came only once. I’m not using Nabu Casa Cloud
Having the same issue here, the integration stopped working a few days ago and it now will not reconnect. Tried all of the above but with no success. Maybe there are more people getting this?
Adding my experience as well, as I’m getting the same error message that the service is temporarily unavailable… None of the workarounds are working for me.
My Miele integration was working fine until a couple of days ago. Now I get the error “Config flow could not be loaded: 500 Internal Server Error got itself into trouble”
Yes, that was it. Having removed the HACS integration and restarted HA, it automatically detected the Miele devices and ran me through the set up for the core integration. All working now - after updating all the changed sensor names.
I also ran into this. In my case, it was down to two things:
I used to use Home Assistant Cloud (Nabu Casa), but no longer do. However, I was still signed in. Go to Settings > Home Assistant Cloud and then log out from there.
I needed to specify my internet-facing hostname in Settings > System > Network.
After making those changes and restarting Home Assistant (Settings > System and then the power icon in the top right), it authenticated first time.
I am in the same boat. Removed the HACS integration, removed Partner Apps from the Miele Account, acknowledged the Data Security Changes in my Miele Profile, have a working Nabu Casa / Home Assistant Cloud setup but no luck on my side - everything I try ends in the “Ups” error message
