My Miele appliances stopped responding suddenly in HA integration. After restarting HA the Miele integration refuses to initialise. The Miele app works normally (iOS). It looks as if the HA integration cannot reach the Miele server anymore all of a sudden. The response in HA is “no internet connection” when I try to reconfigure, while all other integrations work fine. So internet connection must be fine. Anyone else with this problem?
Same here:
Dieser Fehler stammt von einer benutzerdefinierten Integration
Logger: custom_components.miele
Quelle: helpers/update_coordinator.py:405
Integration: Miele (Dokumentation, Probleme)
Erstmals aufgetreten: 25. August 2025 um 16:30:01 (6 Vorkommnisse)
Zuletzt protokolliert: 27. August 2025 um 13:34:23
Error requesting miele data: Cannot connect to host api.mcs3.miele.com:443 ssl:default [Connect call failed ('52.136.216.239', 443)]
Quelle: helpers/update_coordinator.py:398
Erstmals aufgetreten: 25. August 2025 um 15:09:12 (9 Vorkommnisse)
Zuletzt protokolliert: 02:33:31
Timeout fetching miele data
@astrandb do you see the same?
I’m having the same. I am beta testing the new HA release so I was not sure it was caused by that. Are you still on the stable release? If so, you’d best report it as an issue on Github with the integration. If you are also on beta I’ll report it as such.
Problem with Miele’s servers. They seem to be up and running again now.
I had the same. I see it all came back at 10:38am (UTC+1) today.
Hi Ake, indeed back online now. Any plans to develop local access like Home Connect Local, so directly with the Miele appliances to avoid their cloud based services?
No such plans, as there is no known way of accessing the devices locally.
