I’m currently running Hassio, 0.89.1 on RP3 model B.
After several attempts to try to understand the problem, I realized that the miflora package breaks hassio.
When I insert the package, hassio becomes very slow and fails to load the frontend.
If I remove the package all works fine
Did anyone else have the same problem? There is a solution?.
plant:
bonsai:
sensors:
moisture: sensor.bonsai_moisture
battery: sensor.bonsai_battery
temperature: sensor.bonsai_temperature
conductivity: sensor.bonsai_conductivity
brightness: sensor.bonsai_light_intensity
min_moisture: 20
max_moisture: 60
min_battery: 10
min_conductivity: 350
max_conductivity: 2000
min_temperature: 10
max_temperature: 32
min_brightness: 1500
max_brightness: 30000
rosmarino:
sensors:
moisture: sensor.rosmarino_moisture
battery: sensor.rosmarino_battery
temperature: sensor.rosmarino_temperature
conductivity: sensor.rosmarino_conductivity
brightness: sensor.rosmarino_light_intensity
min_moisture: 15
max_moisture: 60
min_battery: 10
min_temperature: 8
max_temperature: 32
min_brightness: 3000
max_brightness: 60000
orchidee:
sensors:
moisture: sensor.orchidee_moisture
battery: sensor.orchidee_battery
temperature: sensor.orchidee_temperature
conductivity: sensor.orchidee_conductivity
brightness: sensor.orchidee_light_intensity
min_moisture: 15
max_moisture: 65
min_battery: 10
min_temperature: 15
max_temperature: 32
min_brightness: 2000
agapanthus:
sensors:
moisture: sensor.agapanthus_moisture
battery: sensor.agapanthus_battery
temperature: sensor.agapanthus_temperature
conductivity: sensor.agapanthus_conductivity
brightness: sensor.agapanthus_light_intensity
min_moisture: 15
max_moisture: 60
min_battery: 10
min_temperature: 5
max_temperature: 35
min_brightness: 3700
max_brightness: 50000
cipresso:
sensors:
moisture: sensor.cipresso_moisture
battery: sensor.cipresso_battery
temperature: sensor.cipresso_temperature
conductivity: sensor.cipresso_conductivity
brightness: sensor.cipresso_light_intensity
min_moisture: 15
max_moisture: 60
min_battery: 10
min_temperature: 5
max_temperature: 35
min_brightness: 3500
- platform: miflora
mac: xxxxxxxxxxxx
force_update: false
median: 3
monitored_conditions:
- moisture
- light
- temperature
- conductivity
- battery
- platform: miflora
mac: xxxxxxxxxxxx
force_update: false
median: 3
- moisture
- light
- temperature
- conductivity
- battery
- platform: miflora
mac: xxxxxxxxxxxx
force_update: false
median: 3
- moisture
- light
- temperature
- conductivity
- battery
- platform: miflora
mac: xxxxxxxxxxxx
force_update: false
median: 3
- moisture
- light
- temperature
- conductivity
- battery
- platform: miflora
mac: xxxxxxxxxxxx
force_update: false
median: 3
- moisture
- light
- temperature
- conductivity
- battery
