edit: Solved in version 0.61 (miflora v0.2.0)
I found a ‘weather proof’ spot to try my miflora sensor outside. Two nights in a row with two different miflora sensors the value jumps to 655350 rather than go below zero.
Before it reaches zero though it reports perfectly.
Is this a hardware limit, firmware, or something on the Hass side?
I double-checked the specs, and it’s rated down to minus 20. So I doubt it’s a hardware issue.
They make an ideal outdoor sensor with a little weather proofing, it’s just a pity about not reading below zero.
Does anyone know of a good alternative to getting local outdoor temperature data in the same price range, battery operated?
