it not just the motion sensors - i have 4 of them in my hallway and i can walk down the hall to the room every work perfect do some stuff in the room for 1-2-3 minutes, and walk back down the hall and nothing will activate
also the motion sensors seem to fade over time and range goes down along with detection speed.
i want to get MM but i don’t see any that are considered good that hubitat can use
Try the easy stuff. Change battery even if they report 100%. Often can happen that sensors are low on battery even if their battery status is 100%.
Home assistant alone will not make your network or sensors better or worst. It will use what you provided. If your network is stable and have a good coordinator it will work just fine in home assistant.
Well it is hard to say is this a network related problem or with hubitat.
I’m just saying that if you have a network problem it will not go away just by switching to home assistant.
You have to decide it for yourself. It is your setup and you know better then any of us how you done it and what problems you are facing.
So how many of those devices for the zigbee and zwave ones are acting as routers for the meshing? and how good is the overall signal strength between them.
As this sounds like your mesh for those protocols is not fleshed out as well as you think you have it and should have it.
I bought some repeaters then based on advice - that later down the road i was told i had too many
So i have tried a lot - when thing are working its perfect light come fast even one far from the hub,
example my office/kitchen lights will turn (far from hub) then when I trigger lights/motion that are FEET from the HUB they don’t work, grab my wallet in the master room and walk back into the haul and they work again.
The advice i was give was remove everything and start over that it must be mesh issue - I do have a lot of zigbee bulbs but i specifically bought the none-repeater type and i have reduce the number by half or more to try and get things working better however this has not made a difference
the weird part it is both zigbee and zwave, all of my motions sensors are zigbee and all hardwired lights are zwave
I should have more then enough repeaters for both networks (and i have channel 9-11 off on my wifi to prevent zigbee interference) I live in the country so i cannot even see any other wifi.
another example - i trying to make new rule and walked into my living room the first 3 lights came on (zigbee bulbs) but t the zwave did not for about 3 seconds and 3 other zigbee bulbs did not turn on at all…
This suggests that it’s not an issue with the motion sensors. It’s an issue with your zigbee & zwave meshes.
How many lights are you controlling at once with your motion sensors? Unfortunately, it’s a relatively common issue that sending multiple commands at the same time will result in lost commands. Setting up zigbee groups helps to an extent, but is not guaranteed to always work. Not sure if Zwave has the option to create zwave groups though.
Try home assistant, why not.
But you might have networking issue as light bulbs are usually bad routers.
If so you will have the same problems using ha.
I predominantly use Hubitat but use HA for things HE doesn’t do. I added a zigbee network on HA specifically for my mmwave sensors because they are VERY chatty.
