Migrating 120 Tasmotas(V12+) to ESPHome
I have 120 Tasmotas devices in my home ( mostly 8266) all are V12 or v15… They are all mounted in panels way high up, not really wire-flashable. So it needs to be OTA
I’m reading that ESPHome might be a bit faster to respond etc.
First, can it even be done, given they are V12?
Second, how do I automate this? Reading about the process this would take days…
Cheers.
Wouldn’t you want to test one or two on ESPhome to verify the claims of it being faster on 8266 before you go down the Automation route?
Well yes, and so far I managed to brick the first one! It binds to the network, but is not accessible… Had to wire-flash it.
But if I know this is going to be such PITA with all of them, slow or fast, I’ll stick with MQTT!
I recently did this. I think my devices where on tasmota 14.
I first flashed to tasmota minimal en then to Esphome.
But be ware that there is this issue with partitioning on the newer tasmota versions.
Automation shouldn’t be that much of a problem if you ask me. Especially if all devices are the same. And you know all op addresses…
Edit: read this https://github.com/esphome/esphome/pull/5535
Thanks.
After I soft-bricked the first one, I proceeded as you suggested. Tasmota-Minimal first and then ESPHome. Worked without a hiccup.
I do know all of my IP addresses and MACs.
How would I go about “automating” this?
Maybe use TasmoAdmin? In theory, it allows me to flash minimal first and then full. I’d just replace full with an ESPhome template. And then customize 120x…
The upgrade issue is specific to Tasmota32, so does not apply to your 8266s. I’ve used the linked PR to convert a few esp32 over the air and it works, but is very time-consuming as it requires a separate esphome install and multiple command-line compilations before you can go back to using your dashboard.
I have almost 40 tasmota devices and about 10 esphome devices — I think there is a place for both, depending what features you need. In practice I haven’t noticed better or worse performance from either, and would definitely not claim esphome is faster to respond — they should both have sub-second response times, if you’re seeing longer it could be a network or config issue that might persist after the conversion. Also with Tasmota I had a few devices that lowering the sleep value improved performance.
Thanks @peterxian ,
I think I’ll leave the Tasmotas the way they are and expand with ESPHome. Tasmotas seems a whole lot easier to set up though, it seems.
TasmoAdmin lets me control the most common stuff from within HA as well.
I did notice something odd: I have a few early sonoff basic R1s. They are at tasmotas V12, but will not upgrade to V15 via OTA (even with minimal first) They do so with wire-flash. I guess the ones mounted and working will stay at V12.
Unfortunately Sonoff R3 Case footprint 1mm wider than the R2. So they are not drop in. Argh :triumph: and the PCB is 3mm longer. Nor do the mounting holes line up.
