Hi all,
I’ve installed the latest update of “Core” yesterday.
Today wanted to access lovelace and I was not able to reach it, anymore.
Directly after the update, everything worked fine, so I assume, it is a coincidence.
My installation has worked flawlessly for more than 5 years on a NUC.
To fix things, I restarted several times and watched the monitor, but there wasn’t even a Bios Menu showing up. I will test a couple of things, but am also prepared to set everything up, again.
I do have a “Full backup.tar” file from last week and I have a Fujitsu 720 remaining.
On my NUC, I’ve had several added functions on my USB ports like KNX-gateway through USB, Zigbee/CC2652RB, rtl_433 antenna, etc.
And of course a lot of Add-Ons.
Before I start this entire mayhem:
What does a “full backup” file even mean?
Can I just install a plain vanilla HA OS on the Fujitsu, attach all USB devices mentioned above and install the “full backup” file?
What makes the most sense from your POV?
Thank you!
