Migrating from Green to Yellow - ZBT-1 Issues
I am attempting to migrate from my HA Green to HA Yellow. I’ve backed up my Green configuration and after restoring it to the Yellow, I can’t get the ZBT-1 stick or my Zwave USB stick to be recognized. The ZBT-1 integration fails to load and says it is not plugged in. Should this “just work” or am I missing something when configuring the new Yellow?
Well, after starting over from scratch, I was able to get it working. I believe the key is to ensure previous hub is shutdown, then connect the zwave and zigbee USB sticks to the Yellow, then re-install HA Yellow and then restore your backup.
Doing that resulted in everything within my Zigbee and Zwave setup coming up back up as expected without any additional re-config being needed.
