Migrating from Synology Docker to Pi (Deconz ZHA problem)
I just installed home assistant on the Raspberry Pi 4b 2GB and migrated all my configurations from the Synology Docker image using the snapshot function in HA. Unplugged my ConBee II stick from the Synology USB port and plugged it in a USB port from the raspberry.
Everything is working fine, except the ZHA integration with 30+ sensors. Is there a way to change the serial settings from the ZHA integration? As i geus that is the problem. Or do i need to redo everything (incl. all automations)?
After waiting ±1 hour, all ZigBee devices magically started working again. This is solved.
