If i know the “Housecode” can i move this one to my RFXTRX without adding it again?. I dont want to go around and “pair” them again. How would such code look like?
That looks like Telldus live if it is then can’t you set the switch on and see what RFXTRX comes back with?
Yeah it is telldus live. Sorry for newbie question but how do i do that?
Not having used RFXTRX - but according to the component you can enable debug and that should print out info to the log file…
rfxtrx:
device: PATH_TO_DEVICE
Configuration variables:
device (Required): The path to your device, e.g. /dev/serial/by-id/usb-RFXCOM_RFXtrx433_A1Y0NJGR-if00-port0
debug (Optional): If you want to receive debug output.
dummy (Optional): Then you have need a connected drive to test your settings. Can be useful for debugging and testing.
So once you have it setup click the button in telldus live website to turn on the device and then look inthe log to see what RFXTRX received.
