I want to migrate my sound from bluetooth speaker (used via mpd) to traditional 3.5mm jack speaker. I sitll want to use mpd, I just want to change speaker. Unfortunately don’t know how to start. On host machine speaker is working:
root@host_machine:~# aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: HDMI [HDA ATI HDMI], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: HDMI [HDA ATI HDMI], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 1: Generic [HD-Audio Generic], device 0: ALC671 Analog [ALC671 Analog]
Subdevices: 1/1
root@host_machine:~# aplay -D plughw:1,0 /usr/share/sounds/alsa/Front_Center.wav
Playing WAVE '/usr/share/sounds/alsa/Front_Center.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Mono
root@host_machine:~# cat /etc/os-release
PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
NAME="Debian GNU/Linux"
VERSION_ID="12"
VERSION="12 (bookworm)"
VERSION_CODENAME=bookworm
ID=debian
HOME_URL="https://www.debian.org/"
SUPPORT_URL="https://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/"
plays a sound. But in guest machine (with ha supervised) device is busy:
root@guest_machine:~# aplay -l
card 0: Intel [HDA Intel], device 0: Generic Analog [Generic Analog]
Subdevices: 0/1
root@guest_machine:~# aplay -D plughw:0,0 /usr/share/sounds/alsa/Front_Center.wav
aplay: main:831: audio open error: Device or resource busy
root@guest_machine:~# fuser -v /dev/snd/*
USER PID ACCESS COMMAND
/dev/snd/controlC0: user 804 F.... wireplumber
root 2356 F.... pulseaudio
/dev/snd/pcmC0D0c: root 2356 F...m pulseaudio
/dev/snd/pcmC0D0p: root 2356 F...m pulseaudio
/dev/snd/seq: user 802 F.... pipewire
/dev/snd/timer: root 2356 f.... pulseaudio
root@guest_machine:~# pacmd list-cards
No PulseAudio daemon running, or not running as session daemon.
even though in xml declaration of machine I’m using configuration which base on debians forum should make sound work on both guest and host machine:
<sound model='ich9'>
<address type='pci' domain='0x0000' bus='0x00' slot='0x1b' function='0x0'/>
</sound>
I know that it may be topic more for debian forum than homeassistnt but I wan’t to avoid creating configuration which work for debian but will be dead end in case of HA. I really want to avoid changing mpd to something else since I’m using it in many places so I want change from bluetooth to 3.5mm jack as smooth as possible. What should I use in this case?
part of mpd configuration which I used till this time:
audio_output {
buffer_time "100000"
type "alsa"
name "JBL"
device "bluealsa:DEV=10:2A:4A:30:21:97,PROFILE=a2dp"
mixer_type "software"
format "44100:16:2"
