Migration from conbee ii to zbt-2 docker container
Need some advice:
I run zigbee2mqtt on a debian 13 server using a conbee ii stick. Everything works fine and has always been stable and all the info gets into home assistant no problem.
I’m thinking of buying the zbt-2 to support nabu casa. If I change the relevant docker compose devices: tag and change zigbee2mqtt configuration.yaml file to the recommended settings for the serial: tag from the website will I have to repair all my devices or is there an easier way to migrate them; or will changing the names tags and keeping everything else the same in the config file keep all the settings?
I’m using home assistant yellow with the mqtt broker on there but like I said run zigbee2mqtt on a debian 13 server with conbee ii
I’m fairly new to all this but am able to find and edit the necessary files should I need to
