Migration from Sonoff ZBDongle-P to SLZB-MR1U – unstable network, worse performance
I want to share my experience migrating from a Sonoff ZBDongle-P to an SLZB-MR1U and see if others have seen similar behavior.
Previous setup (rock solid)
  • Raspberry Pi
  • Sonoff ZBDongle-P (USB extension cable to avoid interference)
  • Ember firmware
  • Zigbee2MQTT
This setup ran for years without issues. As long as I followed the Zigbee2MQTT release notes and firmware recommendations, everything was stable. No performance problems, no instability. ~40 devices (mostly Hue lights, plus some Tuya, IKEA, Gledopto and Wiser).
Why I migrated
I’ve read a lot of positive feedback about SMLight products. The idea was:
  • Replace the Raspberry Pi
  • Run Zigbee2MQTT on my NAS (where I already host other services)
  • Use SLZB-MR1U as coordinator
Migration process
For the first migration I used Radio 1 (EFR32MG21) on the MR1U.
I followed the SMLight migration guide and everything initially looked fine:
  • All devices came back online
  • Fully controllable from Zigbee2MQTT and Home Assistant
After issues started, I switched to Radio 2 (CC2652P7) instead. The behavior was exactly the same, no improvement, equally unstable.
Problems started after a few minutes
  • Devices began going offline
  • Devices became unresponsive
I powered everything down from the electrical panel, waited, powered up the coordinator first, then devices.
They came back online… but then:
  • All lights started blinking
  • Long flickers, repeated blinking
  • Complete “storm” across ~40 devices
Total chaos.
Recovery attempts
I powered everything off again and reintroduced devices slowly:
  • 2–3 devices at a time
  • Waited ~20 minutes between batches
Some devices (mainly Hue and IKEA lights) dropped completely and required:
  • Multiple power cycles
  • In some cases factory reset
  • Remove from Zigbee2MQTT and re-pair
Eventually, I got everything back online and stable.
Temporary stability… then chaos again
It ran mostly fine for a few days.
  • Some failed pings in logs
  • Devices still responded to commands
Then suddenly (a few days later):
  • All lights started blinking again
  • Long flickers, frenzy behavior
This happened right at bedtime, so I had to cut power manually to stop it.
LQI behavior
  • After factory reset and re-pair, LQI is very good
  • After some time, LQI drops significantly
  • Some devices eventually go offline
This pattern repeats with the same devices.
Current status
The network is technically “up”, but performance is much worse than before:
  • Low LQI across many devices
  • Failed pings
  • Devices randomly offline
  • Slower responsiveness
Compared to my previous ZBDongle-P setup, this is clearly worse.
What would you do?
At this point I’m unsure how to proceed:
  • Completely start from scratch (fresh Zigbee network, new network ID, re-pair all devices cleanly)?
  • Or ditch the SLZB-MR1U and go back to the Sonoff dongle?
Has anyone experienced similar instability with the MR1U (on either radio)?
Any advice before I go through another full rebuild would be appreciated.
Update (if anyone else struggling with the same issue find this post):
After days of trying to fix the network after the migration I decided to build it from scratch with the MR1U as the coordinator (new network ID’s), factory reset all devices and paired them to the new network. → Rock solid again (based on a few days testing), maybe even a bit better responsiveness compared to before. So I can not blame the MR1. I still don’t know what the root cause for the instability was though.
I’m about to go through the same exact scenario. Thank you for your post. I don’t think I’ll try a migration. I’ll just start from scratch. Yes, it will be a pain, but I’ll have to just bite the bullet. Thx!
