Migration from venv to Home Assistant OS
Hey guys,
I am a Home Assistant user since long time. At the beginning I used Home Assistant hassbian. That was deprecated and I just continued using Home Assistant within the venv. It works till today.
Additionally I run a piVCCU (Homematic) on that Raspberry as lxc Container.
Today I started playing around with Home Assistant OS and guess what - I want to switch to it and I am asking myself what and how a good practice could look like.
So I try to give you some insights what I am currently using:
  • DuckDns with LetsEncrypt
  • A couple of HA integrations, including some custom integration, all via HACS
  • piVCCU (with GPIO module; I saw that I could use RaspberryMatic)
  • default DB
  • Home Assistant Configurator (I saw it is available as HAOS add-on)
  • ZHA and a USB Stick attached to the Raspberry
My current guess would be, that I copy all the data /home/homeassistant/.homeassistant into the HAOS instance, try to modify the config yamls a bit (i.e. LetsEncrypt stuff, …) and try to start it. My goal is, that I keep my data, my automations, my entities and so on.
Hope to hear your thoughts on my project.
Best,
Dirk
Just wanted to let you know how I solved it:
  • I stopped HA core container on HAOS
  • I copied all the data from the venv config folder, enable hidden files, very important to copy also .storage directory
  • made some small adjustments in configuration.yaml like ssl, removing external and internal url and so on
  • started HA core
Everything went well :hugs:
