Milliseconds
I have the following template switch to simulate a pulse switch:
switch:
    switches:
      blind_kitchen_left_up:
        friendly_name: "Blind Kitchen Left Up"
        value_template: "{{ is_state('switch.modbus_switch_01', 'on') }}"
        turn_on:
        - service: switch.turn_on
            entity_id: switch.modbus_switch_01
        - delay:
          milliseconds: 250
        - service: switch.turn_off
        turn_off:
        icon_template: "mdi:blinds"
and receive the error
Invalid config for [switch.template]: [milliseconds] is an invalid option for [switch.template]. Check: switch.template->switches->blind_kitchen_left_up->turn_on->1->milliseconds. (See /config/packages/logo.yaml, line 28). Please check the docs at https://www.home-assistant.io/integrations/template
But when I look at https://www.home-assistant.io/docs/scripts/#delay I think I did right. Is this my error or a Home Assistant bug?
Kind regards, Christian
Needs to be
        - delay:
            milliseconds: 250
Also note that on anything before the 0.113 beta, it won’t actually be 250 milliseconds. It will basically just guarantee that it happens in the next second.
Does it mean, that in 0.113 we will get more time granurality in scripts/automations?
Yep, see the next release notes here: https://rc.home-assistant.io
I tried doing this in the frontend (edit as yaml) and it is saved without an error message, however, when you edit the automation again you can see that it was changed to
delay: '[object Object]'
