The target was to notify me when it’s time to prep my garden for winter and spring (I’m living in Quebec). I created a input_boolean in HA name summer:
When summer is on, I’m checking if the temperature will be dropping to 0 the next 5 days.
When summer is off, I’m checking if the minimum temperature was positive in the last 21 days.
In case summer or winter is coming, I send a notification to my phone.
It’s my first flow, so I’m sure it can be optimized (any subjection is welcome).
I drop my flow there in case it can be helpful for someone.
[{“id”:“2acfde26.ce8f82”,“type”:“api-call-service”,“z”:“5bdbd6ab.7e392”,“name”:“Winter is coming!”,“server”:“31f480d3.0e3b28”,“version”:1,“debugenabled”:false,“service_domain”:“notify”,“service”:“mobile_app_XXX”,“entityId”:“”,“data”:“{"title":"Winter is coming!","message":"The garden need to be prepared for winter","data":{"push":{"sound":"popcorn.wav"}}}”,“dataType”:“json”,“mergecontext”:“”,“output_location”:“”,“output_location_type”:“none”,“mustacheAltTags”:false,“x”:1770,“y”:400,“wires”:[]},{“id”:“a8513ee4.8af8c8”,“type”:“debug”,“z”:“5bdbd6ab.7e392”,“name”:“Winter is Coming!”,“active”:true,“tosidebar”:true,“console”:false,“tostatus”:false,“complete”:“payload”,“targetType”:“msg”,“x”:1650,“y”:320,“wires”:},{“id”:“635ef727.f1d568”,“type”:“BooleanLogic”,“z”:“5bdbd6ab.7e392”,“name”:“”,“operation”:“AND”,“inputCount”:2,“topic”:“result”,“x”:1460,“y”:360,“wires”:[[“a8513ee4.8af8c8”,“45b62219.849334”]]},{“id”:“f1c8a932.6925c8”,“type”:“rbe”,“z”:“5bdbd6ab.7e392”,“name”:“”,“func”:“rbe”,“gap”:“”,“start”:“”,“inout”:“out”,“property”:“payload”,“x”:1290,“y”:320,“wires”:[[“635ef727.f1d568”]]},{“id”:“45b62219.849334”,“type”:“switch”,“z”:“5bdbd6ab.7e392”,“name”:“”,“property”:“payload”,“propertyType”:“msg”,“rules”:[{“t”:“true”}],“checkall”:“true”,“repair”:false,“outputs”:1,“x”:1610,“y”:400,“wires”:[[“2acfde26.ce8f82”]]},{“id”:“152523d3.dde954”,“type”:“rbe”,“z”:“5bdbd6ab.7e392”,“name”:“”,“func”:“rbe”,“gap”:“”,“start”:“”,“inout”:“out”,“property”:“payload”,“x”:1290,“y”:400,“wires”:[[“635ef727.f1d568”]]},{“id”:“c71532df.3507e8”,“type”:“inject”,“z”:“5bdbd6ab.7e392”,“name”:“”,“topic”:“”,“payload”:“”,“payloadType”:“date”,“repeat”:“”,“crontab”:“00 12 * * *”,“once”:false,“onceDelay”:0.1,“x”:230,“y”:560,“wires”:[[“e5f3dc43.c2637”]]},{“id”:“e5f3dc43.c2637”,“type”:“influxdb in”,“z”:“5bdbd6ab.7e392”,“influxdb”:“1dab2b84.ed7824”,“name”:“dark_sky_temperature”,“query”:“SELECT value FROM "°C" WHERE ("entity_id" = ‘dark_sky_temperature’) AND time > now() - 21d”,“rawOutput”:false,“precision”:“”,“retentionPolicy”:“”,“x”:440,“y”:560,“wires”:[[“2cd41634.4cffd2”]]},{“id”:“f91d7bd3.b19248”,“type”:“calculator”,“z”:“5bdbd6ab.7e392”,“name”:“Minimun “,“inputMsgField”:“payload”,“outputMsgField”:“payload”,“operation”:“min”,“constant”:””,“x”:980,“y”:560,“wires”:[[“f21e161d.6f177”]]},{“id”:“2cd41634.4cffd2”,“type”:“function”,“z”:“5bdbd6ab.7e392”,“name”:“Remove time”,“func”:“msg.payload.forEach(function(v){ delete v.time });\nreturn msg;”,“outputs”:1,“noerr”:0,“x”:650,“y”:560,“wires”:[[“cb7cc5a3.211168”]]},{“id”:“61cbe55a.3eb084”,“type”:“api-call-service”,“z”:“5bdbd6ab.7e392”,“name”:“Spring is coming!”,“server”:“31f480d3.0e3b28”,“version”:1,“debugenabled”:false,“service_domain”:“notify”,“service”:“mobile_app_XXX”,“entityId”:“”,“data”:“{"title":"Spring is coming!","message":"No freezing temperature the last 21 days. The garden need to be prepare for spring","data":{"push":{"sound":"popcorn.wav"}}}”,“dataType”:“json”,“mergecontext”:“”,“output_location”:“”,“output_location_type”:“none”,“mustacheAltTags”:false,“x”:1770,“y”:560,“wires”:[]},{“id”:“cb8ed0e.562e9b”,“type”:“server-state-changed”,“z”:“5bdbd6ab.7e392”,“name”:“Overnight low temperature next 5 days”,“server”:“31f480d3.0e3b28”,“version”:1,“entityidfilter”:“sensor.dark_sky_overnight_low_temperature_”,“entityidfiltertype”:“regex”,“outputinitially”:true,“state_type”:“num”,“haltifstate”:“”,“halt_if_type”:“str”,“halt_if_compare”:“is”,“outputs”:1,“output_only_on_state_change”:false,“x”:310,“y”:320,“wires”:[[“a109b7b8.4f7b1”]]},{“id”:“52cb7137.a120a8”,“type”:“join”,“z”:“5bdbd6ab.7e392”,“name”:“”,“mode”:“custom”,“build”:“array”,“property”:“payload”,“propertyType”:“msg”,“key”:“topic”,“joiner”:“”,“joinerType”:“str”,“accumulate”:false,“timeout”:“”,“count”:“5”,“reduceRight”:false,“reduceExp”:“”,“reduceInit”:“”,“reduceInitType”:“”,“reduceFixup”:“”,“x”:830,“y”:320,“wires”:[[“24b3fbd6.87d2b4”]]},{“id”:“a109b7b8.4f7b1”,“type”:“change”,“z”:“5bdbd6ab.7e392”,“name”:“Freezing”,“rules”:[{“t”:“set”,“p”:“topic”,“pt”:“msg”,“to”:“freezing”,“tot”:“str”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:680,“y”:320,“wires”:[[“52cb7137.a120a8”]]},{“id”:“24b3fbd6.87d2b4”,“type”:“calculator”,“z”:“5bdbd6ab.7e392”,“name”:“Minimun”,“inputMsgField”:“payload”,“outputMsgField”:“payload”,“operation”:“min”,“constant”:“”,“x”:980,“y”:320,“wires”:[[“3b972800.11c47”]]},{“id”:“cb7cc5a3.211168”,“type”:“function”,“z”:“5bdbd6ab.7e392”,“name”:“To array”,“func”:“msg.payload = msg.payload.map(x => x.value);\nreturn msg;”,“outputs”:1,“noerr”:0,“x”:820,“y”:560,“wires”:[[“f91d7bd3.b19248”]]},{“id”:“d754f551.18c528”,“type”:“server-state-changed”,“z”:“5bdbd6ab.7e392”,“name”:“Summer”,“server”:“31f480d3.0e3b28”,“version”:1,“entityidfilter”:“input_boolean.summer”,“entityidfiltertype”:“exact”,“outputinitially”:true,“state_type”:“habool”,“haltifstate”:“”,“halt_if_type”:“str”,“halt_if_compare”:“is”,“outputs”:1,“output_only_on_state_change”:false,“x”:920,“y”:400,“wires”:[[“65b8ea5.0b8ec94”,“152523d3.dde954”]]},{“id”:“319d81b4.2f1c76”,“type”:“rbe”,“z”:“5bdbd6ab.7e392”,“name”:“”,“func”:“rbe”,“gap”:“”,“start”:“”,“inout”:“out”,“property”:“payload”,“x”:1290,“y”:480,“wires”:[[“3ba1bf89.b73c38”]]},{“id”:“65b8ea5.0b8ec94”,“type”:“Invert”,“z”:“5bdbd6ab.7e392”,“name”:“Invert”,“x”:1150,“y”:480,“wires”:[[“319d81b4.2f1c76”]]},{“id”:“43e21895.55d058”,“type”:“debug”,“z”:“5bdbd6ab.7e392”,“name”:“Spring is Coming!”,“active”:true,“tosidebar”:true,“console”:false,“tostatus”:false,“complete”:“payload”,“targetType”:“msg”,“x”:1650,“y”:480,“wires”:},{“id”:“3ba1bf89.b73c38”,“type”:“BooleanLogic”,“z”:“5bdbd6ab.7e392”,“name”:“”,“operation”:“AND”,“inputCount”:2,“topic”:“result”,“x”:1460,“y”:520,“wires”:[[“43e21895.55d058”,“4421328b.a228b4”]]},{“id”:“4421328b.a228b4”,“type”:“switch”,“z”:“5bdbd6ab.7e392”,“name”:“”,“property”:“payload”,“propertyType”:“msg”,“rules”:[{“t”:“true”}],“checkall”:“true”,“repair”:false,“outputs”:1,“x”:1610,“y”:560,“wires”:[[“61cbe55a.3eb084”]]},{“id”:“e94dcc5c.1069f8”,“type”:“rbe”,“z”:“5bdbd6ab.7e392”,“name”:“”,“func”:“rbe”,“gap”:“”,“start”:“”,“inout”:“out”,“property”:“payload”,“x”:1290,“y”:560,“wires”:[[“3ba1bf89.b73c38”]]},{“id”:“f21e161d.6f177”,“type”:“function”,“z”:“5bdbd6ab.7e392”,“name”:“positive”,“func”:“temp = msg.payload;\nif (temp > 0){\n msg.payload = true;\n}\nelse {\n msg.payload = false;\n}\nreturn msg; “,“outputs”:1,“noerr”:0,“x”:1140,“y”:560,“wires”:[[“e94dcc5c.1069f8”]]},{“id”:“3b972800.11c47”,“type”:“function”,“z”:“5bdbd6ab.7e392”,“name”:“Negative”,“func”:“temp = msg.payload;\nif (temp < 0){\n msg.payload = true;\n}\nelse {\n msg.payload = false;\n}\nreturn msg; “,“outputs”:1,“noerr”:0,“x”:1140,“y”:320,“wires”:[[“f1c8a932.6925c8”]]},{“id”:“31f480d3.0e3b28”,“type”:“server”,“z”:””,“name”:“Home Assistant”,“legacy”:false,“hassio”:false,“rejectUnauthorizedCerts”:false,“ha_boolean”:“y|yes|true|on|home|open”,“connectionDelay”:true,“cacheJson”:true},{“id”:“1dab2b84.ed7824”,“type”:“influxdb”,“z”:””,“hostname”:“192.168.XXX.XXX”,“port”:“8086”,“protocol”:“http”,“database”:“home_assistant”,“name”:“”,“usetls”:false,“tls”:“”}]
