Missing Add tab after restoring from a back up
Hello
I have recently changed from a raspberry pie to a mini windows pc with Hyper V and installed Home assistant OS and now I no longer have the Add on tab, also I don’t seem to be able access the config files unless i open the file editor on Home assistant , is this normal.
Thanks for reading this chris
What install method did you use?
If you are using HAOS, then know that the latest revision changed the word Add-on to Apps. Don’t ask why.
HAOS is the only method that uses Apps.
If you installed container method, you generate your own Docker containers to replicate Apps.
Hello thank you for reading my post.
I used the haos_ova-17.0 down load
And that installed
Home Assistant core 2026.2.1
Frontend 20260128.6
Best regards Chris
