Missing API controls for Siemens oven (Home Connect)
I have a Siemens oven (SIEMENS-HS858GXB6) so I installed the Home Connect integration with the Home connect developer account. The integration works but I was surprised that there is no way to set the temperature nor the duration once a program has been selected. I wondered whether it was a limitation from the Home Connect API itself but when using the Home Connect API webclient, I’m able to set these on my oven with a PUT request. Is there any plan to implement these features ? Because they are pretty essential for using an oven. I’m willing to help as much as I can.
You can test the alternative version on hacs.
Maybe that works
Thanks, I had not thought of looking on HACS for an alternative integration and it does indeed include these features.
Hey!
The HA integration has received a revamp and maybe your use case is now covered, would you mind to check it?
