For my vacuum cleaners I would like to show cleaning_time and cleaning_area.
In the IOT Tuya Platform I saw the dps are 119 and 120.
"result": {
"category": "sd",
"functions": [
"code": "power",
"dp_id": 1,
"type": "Boolean",
"values": "{}"
"code": "power_go",
"dp_id": 2,
"type": "Boolean",
"values": "{}"
"code": "direction_control",
"dp_id": 3,
"type": "Enum",
"values": "{\"range\":[\"forward\",\"backward\",\"turn_left\",\"turn_right\"]}"
"code": "mode",
"dp_id": 5,
"type": "Enum",
"values": "{\"range\":[\"standby\",\"smart\",\"wall_follow\",\"single\",\"point\"]}"
"code": "switch_charge",
"dp_id": 101,
"type": "Boolean",
"values": "{}"
"code": "seek",
"dp_id": 103,
"type": "Boolean",
"values": "{}"
"code": "volume_set",
"dp_id": 111,
"type": "Integer",
"values": "{\"unit\":\"%\",\"min\":0,\"max\":100,\"scale\":0,\"step\":1}"
"status": [
"code": "power",
"dp_id": 1,
"type": "Boolean",
"values": "{}"
"code": "power_go",
"dp_id": 2,
"type": "Boolean",
"values": "{}"
"dp_id": 3,
"type": "Enum",
"code": "mode",
"dp_id": 5,
"type": "Enum",
"code": "status",
"dp_id": 15,
"type": "Enum",
"values": "{\"range\":[\"standby\",\"goto_charge\",\"charging\",\"charge_done\",\"cleaning\",\"sleep\"]}"
"dp_id": 101,
"type": "Boolean",
"values": "{}"
"code": "seek",
"dp_id": 103,
"type": "Boolean",
"values": "{}"
"code": "electricity_left",
"dp_id": 104,
"type": "Integer",
"code": "clean_time",
"dp_id": 109,
"type": "Integer",
"values": "{\"unit\":\"min\",\"min\":0,\"max\":10000000,\"scale\":0,\"step\":1}"
"code": "clean_area",
"dp_id": 110,
"type": "Integer",
"values": "{\"unit\":\"㎡\",\"min\":0,\"max\":10000000,\"scale\":0,\"step\":1}"
"dp_id": 111,
"type": "Integer",
"code": "edge_brush",
"dp_id": 112,
"type": "Integer",
"values": "{\"unit\":\"\",\"min\":0,\"max\":10000000,\"scale\":0,\"step\":1}"
"code": "roll_brush",
"dp_id": 113,
"type": "Integer",
"code": "filter",
"dp_id": 114,
"type": "Integer",
"code": "total_clean_time",
"dp_id": 119,
"type": "Integer",
"code": "total_clean_area",
"dp_id": 120,
"type": "Integer",
"success": true,
However, I have no DPS with 119 and 120 in the assignment.
What can I do?
