Missing data from a MQTT sensor
I created a MQTT task. The data also arrive at the HA,
but are not displayed. What am I doing wrong?
Home Assistant 0.46.0:
## sensor mqtt kostal
- platform: mqtt
  state_topic: "kostaldata"
  unit_of_measurement: "kWh"
  value_template: "{{ value_json.day_power_kwh }}"
 ## debug message
  2017-06-13 07:40:58 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on kostaldata:
  	{"name":"Kostaldata",
	 "device":"Kostal Piko 5.5",
	 "state":"15796kWh",
	 "attributes":
	    {"Modus":"Einspeisen MPP",
		 "Day_Power_kwh":"0.35kWh",
		 "Total_Power_kwh":"15796kWh",
		 "Current_Power_watt":"309W",
		 "timestamp":"2017-06-13 07:40:58"
Not an expert here, sorry. I took your info and put it in the Templates page in HASS:
{% set value_json={"name":"Kostaldata",
	 "state":"15796kWh", "attributes":
{{value_json.attributes.Day_Power_kwh}}
It gives: 0.35kWh
So, have you tried this in the value_template?
"{{ value_json.attributes.Day_Power_kwh }}"
Although I’m not sure if it won’t complain about having numbers and characters mixed together. (In the meanwhile, I’m going to see how to split 0.35kWh and come back).
UPDATE:
This works in the Templates page:
{{value_json.attributes.Day_Power_kwh[:-3]}}
and based on this info for nested JSON in a response this also works:
{{value_json['attributes']['Day_Power_kwh'][:-3]}}
Both methods provide: 0.35
Hi timseebeck,
Thank you, it works now.
There is an easier way to map the attributes.
I still have 37 other sensors and it would be easier if there is a generic method.
2017-06-13 11:29:45 DEBUG (MainThread) [homeassistant.components.mqtt]
	 "attributes":
	  {"pikomodus":"Einspeisen MPP",
	   "pikoday":8.81,
	   "pikototal":15804,
	   "pikocurrent":3280,
	   "pikotime":"2017-06-13 11:29:45",
	   "pikodevice":"Kostal Piko 5.5"
- platform: mqtt
  name: "Piko Tagesleistung"
  value_template: "{{ value_json['attributes']['pikoday'] }}"
- platform: mqtt
  value_template: "{{ value_json['attributes']['pikotime'] }}"
- platform: mqtt
  value_template: "{{ value_json['attributes']['pikomodus'] }}"
- platform: mqtt
  value_template: "{{ value_json['attributes']['pikocurrent'] }}"
  unit_of_measurement: "W"
- platform: mqtt
  value_template: "{{ value_json['attributes']['pikototal'] }}"
Glad you get it working!
(wow, 38 sensors! lots of fun)
Yes, a lot of devices…
