Missing Entities after Z2M Pair of TS0601_dimmer
I have the following dimmer switch by MOES:
TS0601_dimmer_2
It’s being detected perfectly well including all brightness options.
However, there are no Entities for setting up the brightness although the sliders do work in the Z2M device menu.
just to update,
i found that if you press on the bulb icon you can actually run the brightness up and down.
but how can you control it from an automation is what I dont know…
