I purchased a “Tuya WiFi 4 Channel Temperature Humidity Smart Switch”. Everything works perfectly through the Tuya app. I reloaded the Tuya integration on Home Assistant and the new device appeared on the list, but only 2 switches and the temperature sensor are shown. The other two switches do not appear. I checked the Tuya developer platform and the new device is listed there with all switches. I tried switching from “Standard Instruction” to “DP Instruction” (I read somewhere that this could solve the missing entity detection issue), reloaded the integration, but it didn’t work. On the Tuya Developer Platform instruction mode page I see:
Table of Instructions
switch_all switch_1 switch_2 work_mode temp_current upper_temp lower_temp countdown_1 temp_correction fault humidity_value maxhum_set minihum_set switch_auto_1 switch_auto_2 alarm countdown_2 relay_status Sensor_Dect TPMC switch_4 switch_3 countdown_4 countdown_3 child_lock switch_inching switch_auto_3 switch_auto_4 hum_calibration temp_sensitivity hum_sensitivity tpm_alarm hum_alarm1 alarm_enable
How can I access all these entities? Or, at least, the two missing switches? Is there a way to manually edit the configuration file for the devices/entities of the integration and manually include the entity by name?
I have the same problem in other Tuya devices too.
Thank you in advance! Any help would be greatly appreciated.
