Hello, i just deployed Home Assistant on my Qnap using Docker, but i seem to be missing the integrations menu in config? - the last image i used had it. auto discovery seems to be working, but i cant actually configure anything via the GUI
Hi, did you sort this out - I just got the latest stable docker image running and also don’t have Configuration → Integrations menu item
My version is 2022.2.6
My problem was caused by DNS not working inside the docker container, fixed it like this:
Then had to clean down and reinstall and then HACS worked.
Still didn’t get menu item - but maybe it’s moved to configuration → devices & sevices → integrations as I could add my tapo cameras there
all works now
