I have an issue after upgrading the palette
Some nodes are missing
I only have those two blocks
I tried to uninstall the add-on and install it again but nodes are missing again β¦
Do you have an idea how to solve my problem ?
is someone could help me with this issue ?
Instead of removing the add-on, try to remove the nodes (hamburger menu at the top right of the screen > Manage pallete > scroll to node-red-contrib-home-assistant-websocket) and remove it. Then, restart the addon and try to readd it.
If all that fails, you can run NodeRed by itself on a Pi or another computer and see if you can get them to install there and/or do a command line install.
Thank you for your reply.
When I try to delete the node-red-contrib-home-assistant-websocket I have this message
Failed to remove: node-red-contrib-home-assistant-websocket
Type in use: server
Check the log for more information
I use Hassio so I canβt access to command line
Where ever you have those nodes in use, delete them. Worse comes to worse, export your flows to a separate file (hamburger menu > export > all flows (at the top) and then hit download) and delete all your flows.
Then, try to remove the nodes again, restart the addon and try to re-add them. Should all that work, you can import the file you just generated and not lose any of your flows.
issue solved.
I had to remove the addon and delete the node-red directory
Thank you @code-in-progress for your help
