Missing Sony Songpal integration
I just got a Sony HT-XT3 and tried connecting it to HA. However, wneh I go to Settings->Devices and Integrations->Add Integration, I can’t find the Songpal integration.
I’m running HA in docker and the version is from Dec 2023 so everything seems to be up to date.
If I go to the Songpal integration webpage and click on Add to my HA, it takes me to the HA UI and then complains that this integration can’t be added from the UI. This is weird as the documentation clearly states that it can be added from the UI (in the Manual Steps section). The webpage I’m refering to is: Sony Songpal - Home Assistant
So I guess it’s 2 questions in 1 post:
  1. How do I get the integration to show up in the list
  2. Can this integration only be added through YAML?
Thanks,
Gaurav
I manually edited my configuration.yml to add:
songpal:
  endpoint: http://<IP>:10000/sony
Restarted HA and got a notification that a new device has been added!
Still can’t answer why the integration didn’t show up in the GUI though
