I have a group configured with two members. When I’m looking into the developertools I can see the current state: ‘not_home’
When I configure an automation with this group, I can’t choose this state (nor ‘home’) in the enum dropdown field. Is this a bug or do I configure something wrong?
Thank you for your help.
There are many possible states for groups in general, so the system can’t provide a full list. You should be able to type not_home into the field. I’ve just tried it:
…and it translates it to “Away” in the header. It’s not ideal, because if you type Away in the field it’ll look the same in the UI but not work because the true state is not_home.
