Missing Tuya Thermostat HVAC Modes and Fan controls
This Tuya thermostat is able to simultaneously manage “Heat Floor” and “Fan Coil” systems. It is ideal for air-source heat pumps such the Daikin Altherma ones.
The Tuya APP works seamlessly allowing to choose between all 5 climate modes: Cold, Hot, Wind, floor heat and floor+air.
But inside HA this is a different story. After installing the integration only recognices 3 climate modes:
I’ve tried to add more climate modes using the “Feature Editor” of the “Climate Card” but they don’t show up (and also there aren’t specific HVAC modes such “floor heat” and “floor+air” in the Climate Integration)
Besides, all the Fan controls are missing in the HA Climate Card (no way to set it on Auto, Low, Middle or Low speed)
Is this a problem of the Tuya integration? or is this a problem with the Thermostat manufacturer? or is a problem of the Climate Integration? or, most probably, is a problem with my incompetence using HA? :rofl:
Hello MattrixST,
There is a reason there are many Tuya integrations. The one in HA core is written by Tuya engineers, but is slow at keeping up with their own stuff. some of the custom Integrations for Tuya that can be loaded thru the HACS loader support different things.
